I don't go back to school for another 16 days dude.
It's an excuse to sit on SAU all day, not have to go outside and get my precious skin burnt by the harmful sun, and be in contact with the public.
Hahaha :unsure:
1. Do you feel the current P plate restrictions are suitable?
No
2. Would you drive a prohibited vehicle (turbo, v8) if you could?
Yes
3. Do you feel you take more care around P platers on the road?
No
4. Do you like the idea of having a passenger limit for P platers?
No
5. Do you regulary (atleast once everyday) speed (purposely go over speed limit)?
No
7. Do you follow the speed on the freeway and stay within your 90 or 100km/h limit? (If you have one)
Yes
8. Has all the recent articles about P plater deaths made you slow down?
No
9. Do you see more P platers doing the right or wrong thing when you are out driving? (Be honest please)
Right
10. Do you think passenger restrictions will solve the P plate death issue? Or does more need to be done?
No
11. Do you trust getting into a car with a P plater? Or do you trust your child getting into a car with a P plater?
Yes
12. Please tick what licence you are on:
Full Green Ps
13. Are you male or female?
Male
P-Plater Survey
No
I'm off P's
Yes red ones
Yes
Yes but only a couple of km/h
Don't have one
Yes
Right
More
Yes
Full
Male
Thanks guys.
Filled them all out.
Just entering in the numbers now :D (in Excel).
Thank you once again for helping me with this. As it looks there are quite different opinions about the P plate issues, but thanks for all your input.
No more surveys need to be done thank you
  • 2 months later...
Sorry to rebirth an old thread.
Just wanted to thank everyone once again for their help.
I think the result is pretty self-explanatory.
Thanks guys.
I put A LOT of time into this, and thankfully the teacher saw that.
Was pretty funny, the class got a two week extension because no one had "finished" (started lol) when we started this year (when it was due).
Maybe i'm just a nerd? :(
Males: Yes – 8 – No – 12
Females: Yes – 11 – No - 9
Yes
Male Female
10 4
No
Male Female
1 11
I'm off Ps (Doesn't affect me)
Male Female
9 6
Do you feel that you take more care around P platers on the road?
Yes
Male Female
12 10
No
Male Female
8 10
Yes
Male Female
10 5
No
Male Female
10 15
Do you regularly (at least once everyday) speed (purposely go over the limit?)
Yes
Male Female
6 3
No
Male Female
9 8
If I'm in a rush
Male Female
5 9
(If I'm in a rush was a trick :( - Basically saying yes but not wanting to admit it)
Do you follow the speed on the freeway and stay within your 90 or 100km/h limit (if you have one)?
Yes
Male Female
8 7
No
Male Female
5 8
I don't have one
Male Female
7 5
Have all the recent articles about P plater deaths made you slow down?
Yes
Male Female
6 10
No
Male Female
14 10
Right
Male Female
8 10
Wrong
Male Female
12 10
Yes
Male Female
6 2
No
Male Female
7 9
More needs to be done
Male Female
7 9
Yes
Male Female
12 15
No
Male Female
8 5
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
    • When I said "wiring diagram", I meant the car's wiring diagram. You need to understand how and when 12V appears on certain wires/terminals, when 0V is allowed to appear on certain wires/terminals (which is the difference between supply side switching, and earth side switching), for the way that the car is supposed to work without the immobiliser. Then you start looking for those voltages in the appropriate places at the appropriate times (ie, relay terminals, ECU terminals, fuel pump terminals, at different ignition switch positions, and at times such as "immediately after switching to ON" and "say, 5-10s after switching to ON". You will find that you are not getting what you need when and where you need it, and because you understand what you need and when, from working through the wiring diagram, you can then likely work out why you're not getting it. And that will lead you to the mess that has been made of the associated wires around the immobiliser. But seriously, there is no way that we will be able to find or lead you to the fault from here. You will have to do it at the car, because it will be something f**ked up, and there are a near infinite number of ways for it to be f**ked up. The wiring diagram will give you wire colours and pin numbers and so you can do continuity testing and voltage/time probing and start to work out what is right and what is wrong. I can only close my eyes and imagine a rat's nest of wiring under the dash. You can actually see and touch it.
