Hey guys
just tried doing a service .... oil filter was abit hard to turn ... after alot of effort and few tools my oldman squashed the filter removing it but also broke the BOLT that the oil filter screws onto..
now there is half a bolt left inside the oil pump thing where the oil filter fits into and half we have in our hands..... what do we do to get da oda piece out or.... how should we go about this now? put in da towel and get a mechanic to look at it or what?
cheers
https://www.sau.com.au/forums/topic/151645-oil-filter-bolt-broke/
you need a new oil filter bracket. your whole oil filter bracket/cooler comes off. if you want a proper fix then replace the oil filter bracket.
heres the part out of the workshop manual:
the part shouldnt cost too much 2nd hand, just get one off a wrecker (make sure you clean and blow it out before putting it on!!), might be a bit of a bitch to get to though.
its split in half.... maybe an inch is left inside and then the other half with the nut and bolt..
oil relocation ?
its a bloody tough job , to change the whole thing, how long would replace it usually take. oil relocation kits approx price wise and reliability what would be the better option?
p.s what would be the better option we've already taken the 4 screws out but its not comming off is there a sealant or sumthing that we have to remove ???
Edited by Zas)-(
there usually is a bit of sealer.
get a heat gun or a hair dryer and heat it up and see if that works.
half of the thread isnt much, especially when the oil filter is tightened by hand. i wouldnt risk using the broken thread unless you were completely confident that it would hold.
no way its only got a bolt of lcm popping out of the actuall bracket thats left we are trying to get the bolt out but no way cant do anything for it...
yeah we could try a heat gun , we dont have to remove the actual oil cooler from the filter bracket itself?
I'm just wondering, for future reference sake so that I don't do it to my car:
The oil filter is normally on not that tight (how tight can you possible tighten it since you tighten by hand, without any tools).
How tight was it, and how on earth did the oil fitler bolt break?
What removal methods did you try before you tried to squash the fitler in. Did you try sprayin git down with carby/brake cleaner to remove all the oil so you can get a grip and use a grippy pad (those you buy from the supermarket)?
it was the mechanic,.
we used the claw device u find in repco and the strap on oil filter so we have tools to take it off not some cheap oil wrench from kmart.
but these tools usually arent required most are done by hand.
...i reckon the bolt broke because of so much heat.. like manifold studs break i reckon the bolt was going soon too from pressure n heat..
hahaha wheres ur car kinks i'l lsend some1 to take good care of it :O
Ouch, hope it doesn't cost you too much to replace man.
Oil filter relocation kit, i believe, is a must on any Skyline (or any car for that matter) Makes its a 60 second job. Check below for instance, bolt one where the filter used to go, the other has the filter screw onto it, place it where you want.
Anti seize on the thread (loctite make a product for instance) and a smear of oil on the filters rubber o ring makes it a lot easier for next time.
- M
I have zero problems removing my oil filter by hand. On a GTR, maybe things are a bit tight.. on a GTS-t there is loads of room!
I just get in there with both hands and give it a twist. Only do it up as tight as I can by hand too so it's not too hard to remove next time. Rule of thumb is you always need a bigger tool than you used to do something up to get it undone again. If you put your oil filter on with a wrench you're f**ked.
I use a rubber glove to remove mine. For a little added grip so it can be done with one hand and so I don't get burnys.
Only ever do it up 2/3rds of a turn as the instructions state.
IF its stuck on simply smack a screw driver through the end and turn. :happy:
I'd say its broke because it was probably pushed rather than turned. Either that OR it was tightened up instead of loosened. :(
    • Thanks for all the replies fellas. Gonna finish putting it back together and see how it handles the set up. If it starts pinging it’ll be parked.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
