i've got a full house RB26 with
HKS 25/40 turbos,
full decked head intake and exhaust
HKS 700cc injectors
Nismo adjustable fuel reg
Split fire coils
Apexi camshafts 280
Apexi head gasket
SS Valves
Pistons
Rods
Crank
N1 Water + Oil pump
with front LSD
All work was done in japan, egine came across as is with car.. i've spent plenty of $$$ on detailing and extra performance bits
Came from my R32 GTR which was written off, got hit in the back..
Located in Sydney, $25K now $20K or make an offer
0433 384 056 DAYTIME
pics are posted
Edited by WLD_GTR
https://www.sau.com.au/forums/topic/151712-full-house-rb26-turbos/
Mate i understand and thanks for the heads up, But here u get the quality and reliability of full house workshop engine from japan.. also $25k is just a starter i did mention to Make An Offer, but i shall drop the asking price too.. thanks
Sorry i dont noe wat crank, rods, or pistons are in there.. but iam guessing from the apexi head gasket and camshafts that it would be all apexi.. iam not to sure on how much kms since it was built or who built it.. as i previously said that i purchased the car from japan and the motor was already in it. So as i previously said it is a complete built engine from a workshop in japan. You cant go wrong with the quality and reliability from a japanese workshop. Also with the HKS 25/40 turbos already bolted on. No it is not an N1 block
Edited by WLD_GTR
Japanese workshops are just like Aussie ones...there are good and bad...for all you know it could be a STD bottom end with bolt on's done on the grass under a tarp beside his lean-to. Some REAL facts and information about the product your selling would be a good start. 2540 turbo's have been out of production for a few years now and yours look a bit tired. It could have been built more than 5 years ago and possibly has plenty of klms on it. A realistic price would be a good start too....possibly even less than half your current price may find you a buyer.
  • 1 month later...
ill offer u $6000 IF it passes compression? you can keep the turbos...... and ill come pickup today?
That's a great offer. I'd consider taking it if I was you.
My mates R32 GTR made 450 kw at all 4 on the Autosalon dyno with a big single. :rofl: He thought it had a built bottom end even a storker. Some time later the engine spun a bearing from cracking a oil pump.
He was devstated and happy at the same time finally opening his engine and seeing the bottom end was totally standard. But he was happy to have produced 750-800bhp with standard pistons and rods. :)
Just shows what an amazing CRD tune can do :P
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
