Hi,
I was spending hours in this forum, trying to gain some information about save boost limit with stock R32 turbos etc., I din´t quite find the answers I was looking for.
I certainly know how to use the search button, but like when I was looking to get some stock turbo compressor maps I just found posts about A/C compressors etc.
Something really confusing I found out were power ratings on stock turbos on different boost levels.
Many people here are talking about drivetrain losses of over 40% im 4wd mode, or that aiming at 200awkw is almost impossible without many mods.
So just to shorten everything a bit, I better just post a dyno sheet of my car with a Mines ECU mapped for 0.9 bar, with M´s intake without heatshield, 3.5" invidia full exhaust and catalic converter NOT removed.
Then you can tell me how I got all those number faked, or - what I would appreciate - how I could further increase my power output without replacing the stock turbos or intercooler...that I think can´t be as bad as people tend to say - I mean, a pressure drop of 0.3 bar above 6rkm?! Wake up...how should Nissan have stayed in front of the competition with this piece of shit then...if those shitty ICs weren´t replaced in race series.
Maybe someone even has got the compressor and turbine maps for me, I would be quite thankful for that kind of information :O
Cheers,
Andy
PS: I could also include a torque split curve or the protocol file I got, so everybody could get the Superflow tool to check everything interesting out by himself.
Edited by AndyStuttgart
https://www.sau.com.au/forums/topic/151730-bnr32-dyno-run-turbo-questions/
Good son of rajab, you've traveled a long way my friend.
For starters the "SuperFlow" dyno that you’ve used, had printed out a graph not many are familiar with, are you able to annotate back to English what the scales and values mean?
Max Boost - It has been covered plenty of times, and usually comes down the size of ones gonads. BNR32 ceramic wheels, have been known to pop at 12psi, been known to go strong at 16psi+ for years; how yours will fair depends on age, condition, previous owner etc etc. If you cant afford any $$ hassles at the moment, i would stick to around 10psi (personally)
AWD Loss - 20-25% for Engine >> RW loss, then maybe 4% for RWD >> AWD loss is I think, accepted. I rekon your package would be about 220-240 rwkw’s on a Ozzi dyno (Dyno dynamics)
As for increasing power with std turbo’s… depends on how much extra your after. Anything worthwhile, your going to have to change them.
Intercooler – Sorry bra, most ppl praise the stock GTR coolers, are you saying you’ve measured a .3bar restriction above 6000rpm?
Sorry cant help with stock turbine compressor maps.
Good luck man, hope you whoop many a Beema :P
Edited by GeeTR
200 aw kw should be easy with stock turbos on 9psi
i have a mines ecu on mine and on stock boost with turbo back zorst and pods its running 196.4 kw @ all 4 wheels i havent had it on dyno since i put boost controller in but am hoping for about 210 -215 @ 14 psi
thats the sort of dyno readings we understnd over here lol
I will do that later, and try to get those scales into PSI etc.
I thought about installing the AVC-R black edition I jsut got, and setting the boost to about 15.5 psi from 3,5krpm to about 6krpm, and letting it drop to about 13 psi at rev limit (8,5krpm).
Do you think this would be ok since I have lower boost at higher revs?
Tubbies should remain stock as this R32 is going to be sold when it´s street legal - there aren´t that many Skylines over here yet :O
For upgrades I still got my (side impacted) R34 GTR that will only get Germany´s finest engineer ideas to make it a real rocket, after it´s repaired *g*
Not by any means I think that there is such a drop, when you take a look at the boost curve you can see there is nothing like it in my dyno sheet - I just got this information from some thread in this forum that there should be this obvious boost drop above 6k...
Good luck man, hope you whoop many a Beema :)
As long as they´re not turboed - for sure :O
Looks like I can´t change the units in my dyno chart - sorry...
But I´ve got two new questions, would an water injection help out to make the ceramic exhaust wheel live longer under higher boost settings?
And would two R34 GTT turbos fit an RB26, has somebody already tried this?
G’day Andy,
For the graph – even if you cant get the actually graph changed, can you find out what the right and left hand column is, and what UNIT of measurement its in? Surly for it to be useful to yourself or your tuner, one of you must know – at least then I can roughly translate it, as now, I’m clueless.
I believe the wheel falls of due to excess heat, so limiting impeller RPM in the higher rev ranges would help… though still no safe guard, as they’ve still been known to fall off at your “low” 13 PSI setting.
Water injection alone (without the usual winding of ignition and leaning of mixtures) would help I would think… but like my previous analogy, you can use both hands to cover em, but in reality that penalty ball is going to f-cking sting if it hits you :)
Considering your selling the car, do you really wanna fork out for a replacement turbo, labor (if you ain’t handy with the brandy) and maybe a dud motor
Id say two tahbins, originally meant for 2.5 on a 2.6 is going to be mighty laggy.
Yah, I rem going through a German / Swedish (?) workshop site 6 months back, with a few 1000hp turbo V12 BMW’s. There’s a few 700HP E30’s here in Oz. I’ll rest on the fact, they are all RWD hehehe 
- M
Left unit is kilowatts, right is torque in newton metres.
So for the torque, compare the red line with the right column, for all wheel power check the brown line with the left column, as well for the blue line (flywheel kilowatts).
Purple line is boost in Bar * 100 (so it´s about 0.9 Bar / 13Psi).
Green is drivetrain loss (left column) in kW.
Orange is a/f ratio in lambda *100.
safe leval is usualy less that 1 bar.
avcr is nopt a very good boost controler. very tricky to get working well.
greddy or blitz twin solidoid are far better. and take very little time to set-up.
but having said that.. ive seeen bog stockl r32gtr turbos die on standard boost. (11-12psi)
I think what kills most turbos is stock exhaust with boost upgrade - too much backpressure in combination with excessive heat isn´t a good combination at all...
    • it was good to see our presence at GTR festival..hope to see more SAU at these events
    • This is awesome.
    • Thanks for the quick replies guys its appreciated. A small extension was welded onto the standard 6boost external gate pipe which you can see where the pipe goes from black to stainless just below and to the right of the rear housing in the first picture. Overall I would say the flow is pretty good other than 6boosts choice to come straight off the collector at a decent angle.. Not sure why I went with two valves, I originally replaced the stock twin bovs with the GFB when I had the twins on. When I purchased the EFR it came with the Turbosmart Kompact BOV so I figured that would be a better option than the stock EFR Bov. I don't believe the Turbosmart BOV is adjustable? When I get the spike and then sudden dip in boost pressure, the turbo speed does drop as well. Stock head size wise however I believe it has Neo Turbo springs and a Neo Turbo intake camshaft and an aftermarket exhaust camshaft in the vicinity of 260 degrees. We didn't try a different MAC valve, we tried two different ways of plumbing it and we also tried removing the mac valve entirely and just having the boost source from the turbo directly connected to the wastegate and it still spiked / dropped and exhibited the same behaviour. Standard R33 GTR 5 speed tansmission. I'm running a Haltech Elite 2500 and can provide some logs if you. I understand what you're saying in that it looks like an auto plot however no, it's still a manual and it just has a lot of torque down low, for all intents and purposes it's a very impressive street car. I've attached a photo of the quickbitz dyno plot which was when the only difference is I was running -5 twin turbos with a mac valve. As you can see theres a decent dip in AFRs between 125kmh and 135kmh. Our problem now is not that the AFRs are dropping, just the boost pressure is dropping, however it is evident in the same RPM range of the map, coincidentally or not.
    • What transmission are you running?  It's a bit tricky with the scaling, but at face value the power "curve" looks more like a "line" which is a bit odd... basically a lot more like a dyno plot I'd expect with a highish (compared to a factory auto) stall torque converter type setup. If this is running an auto then this kind of boost control challenge is definitely a thing, the rpm scale on the dyno doesn't reflect what the engine is actually doing (unless the dyno has access to the engine's ACTUAL speed electronically) and what you'll get is a big rpm flare up as the engine torque launches past the converter pump's ability to resist torque at that rpm, then as the converter starts picking up rpm it will kinda even out again and the engine rpm will pick up more steadily. The trick with this "flare up" is if it's kinda near the boost threshold for the turbo then the engine's airflow requirements to maintain the previous boost level will outrun the turbo's ability to supply that boost - so you end up with a natural flattening off, if not dip when that happens.   If you are running closed loop, or even tune the "feed forward" wastegate duty cycle to deal with that rpm spike then when the engine starts settling to a more typical climb you'll actually have a situation where the gate is "too closed" and boost will run away for a bit, then have to pull down again.      It's not trivial to get this perfect as most boost control systems are generally expecting more predictable engine rpm rates of change, but if you *know* that's whats going on then you can at least "accept your fate" and realise getting that area perfect is kinda chasing your tail a bit, and assume that if the rest is working sensibly and the spike/dip isn't completely uncontrolled then you should be good. Sorry if I've gone off on a tangent, but the dyno plot and boost control behaviour look a LOT like what I've seen tuning autos in the past. What ECU are you running? Could possibly be convinced into looking at logs if I get too bored this weekend haha.
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
