i didnt do the group buy because not enough people replied there were a few people keen but no one replied when i asked so i did not have enough for the group buy
minimum is 5 people for group buy if i can get 5 people i will do the group buy
  • Replies 43
Can anyone who wants in post please so he can get the minimum 5 required for the group buy.
1. rb180 (H3 6000K)
2.Jaqule (H3 6000k)
3.
4.
5.
Add your name to the list.
I'm in
1. rb180 (H3 6000K)
2.Jaqule (H3 6000k)
3.Gengis (H1 6000K)
4. HellaFlush (H4 8000k)
5. Nuganen (6000k)
where do you look to find out if its a H3 or H1 in a skyline gtr r32 89 model
cheers
Edited by nuganen
I'm in
1. rb180 (H3 6000K)
2.Jaqule (H3 6000k)
3.Gengis (H1 6000K)
5. Nuganen (6000k)
cheers
i was told that H3 will fit a 32 gtr mate. thats what im getting for my 90 gtr32
Hi guys, you can check what globe you have in your car by pulling out the existing globe and just look around the base of it. It should say whether it's a H3, H1 etc. If you still can't identify what it is, just bring it to autobahn or repco and they should be able to help you out. You wouldn't want to buy a kit with the wrong globes.
By the way, these kits have not given me any problems so far.
Cheers
Adam
Sorry guys but I'm out, Nismos15 did say it ended on 10th/Feb and looks like he hasnt been on here for a while.
I'm going to source it from Ebay, if you guys are interested this is what I'm looking at
http://cgi.ebay.com.au/NEW-XENON-HID-CONVE...1QQcmdZViewItem
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
