:happy: You can convert your R34GTT to look like as R34GTR with genuine R34GTR front bar and bothside guards..
parts just for ..$1300.-
other parts also for sale...
R34GTT Tein adjustable suspension...$500
R34GTR Vspec II Nur genuine original exhaust...$250
RB26DETT new stenless 3" downpipe ...$350
R33GTST right side head light...$50
R33GTST original exhasut ...$100
R33 GTST original rims with brand new tyres...$300
R32GTR kakimoto exhaust...$400
R32GTR original intercooler....$250
Advan 17" wheels with tyres 9JJ fit to R32GTR....$500
celsior Luxus 400 airbag suspension.....$500
thanks mate
Edited by netsky
you willing to post the gtr bar to syd?
Hi ..May be able to post to syd....if you can help for the postage...
fastway couriers is very good..please visit their web and check if you like to use their service..
www.fastway.com.au
3 parts ( front bar and left and right side guards) only...
not include front bar lip
regards
Tony
Edited by netsky
Hi, how many km have the R34GTT coilovers done and what brand/model are they?
Hi Mate...it was on R34GTT with about 70000km...and will check which model....it Tein ...
regards
bothside guards? are these the rear flared guards? because not sure how you are going to seperate them but interested in buying
Hi mate....the R34GTR genuine front bar and front both side guards was sold yesterday....
thank you...
regards
(if you are looking left side guard ...then i know the guy may want to sele it...)
hey mate, can you give us some more info on the coilovers and whether ur willing to ship them at buyers expensive, very interested
Hi mate...I have after market Tein and bulsteen and nismo suspension for R34GTT...
all of them can adjustable hard and softness..it 3 level hight adjustable...please see the pic on up this page of my reply to other person...
I will put up those pics at the this weekned once I got the pics taken..
regards
Pictures of "R34GTR Vspec II Nur genuine original exhaust"?
What is the diameter of the pipe (apologies for my lack of knowledge here!)
Cheers
Luke
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
