all prices are somewhat negotiable so dont be afraid to make me any offers. cheers
Maurice
Item: Tein HA coilovers. done 40000 kms.
Item Condition: near new perfect condition
Reason for selling: no longer needed
Price and price conditions: $1000
Item: full turbo back 3" exhaust with 5" Xforce canon done 30000kms
Price and price conditions: $750
Item: Work meister 18x8" rims. Fronts nankang 255/40/18 (60%) rear Yokohama 255/35/18 (90-95%)
Item Condition: good condition few gutters nothing major.
Price and price conditions: $1000 with wheel swap (any rims doesnt matter) $1300 no swap
Edited by ssslpr
https://www.sau.com.au/forums/topic/151999-various-r34-gtt-parts/
Are the Tein HAs the hard ones or the soft (street) ones. How hard are they compared to stock? I take it they are height and damper adjustable? Pics?
they are stuff yes but not overly bouncy. they are ALOT better than the super street ones. these are semi track spec but still very comfortable. they are height and damper adjustable yes.
pics will try get them up tonight.
I want coilovers that are a LOT like stock springs/shocks as I use the car all day for work. So you say the HA's are softer than SS's or harder?
Do they come with camber tops? If not, I can buy the same from Greenline for under $1,000 delivered to my door brand new ....
They are harder and alot better quality then SS. if you want soft springs like stock whats the point in upgrading? i'd appreciate you not "corrupting" my thread and suggest buying them from greenline. don't post shit on my thread. thanks
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
