  • Replies 73
Posted Images
well thanks to the show n shine on the 17th, i'm now making the date either the 23rd or the 30th of June
jez....i'll be glad when we are finally there on the day!
please let me know if you can not make either day.....
I've booked and paid the deposit for the 30th. so it's officially a goer.
i said we may have a few extras, so its no problem if you have someone else who would like to come. just let me know. cheers :action-smiley-069:
I'll post a map and time we have to be there soon.
Don't forget to bring some extra money to buy more paintballs. 100 paint balls are included in the pakage, but i'm sure you will shoot more than that :thumbsup:
also bring some groin protection (ouch) and gloves are also helpfull.
lunch is included as well, so no need to worry about food
Check their website if you want to know more. (Kulnura Paintball)
Check the first page post for prices of paintballs.
not a problem....same deal...just let me know when the money has been deposited. I've booked and paid for 6 so far, but I let them know that we might book for a couple more. it needs to be done 2 weeks before though...
i've booked for the 30th of this month, but the show and shine has been rebooked for the 1st :P
is it fine if i re-book (again!) for the 7th of July? just might be easier than getting the car ready for the SnS the next day!. please let me know asap....
if this date is no good, we can make it the week following. please let me know if you are available on that day anyway
cheers,
Chris.
pm sent ian :(
I'll say yeah at the moment, only due to money constraints, but I still think it'd be cool to do both on the weekend as it would make for some cool conversation pieces the next day with all our bruises and stuff :(
the only problem that i was thinking, is that we would have to spend the afternoon after we finish at paintball cleaning the car for the show and shine the next day.
so i was thinking the 7th would be a better date, unless the original date is prefered.
edit....sorry just read you post on the drift nationals. is this what you meant for the next day? if so i think that would be pretty sweet. just didn't want to go to the sns the next day :worship:
wOOt!
just re-re-re booked and paid for paintball. it is now a go ahead. no more date changes.
new date is Sat the 7th of July at 8.30am
100 paintballs is included. parking is no problem.
they said we can have a special rate of $80 for an extra 500 paintballs ($16/100 balls). but the catch is everyone has to do it to get that rate. otherwise it is $22 per 100 which is still ok.
anyway, it will be stacks of fun!
and it is still ok to book a few more people into our group. just have to give them enough notice
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
