Hi guys,
I want to know if your standard ECU gives u any warning if it detects high knock levels?
My first r33 dusted it self in one nght due to exesive knock. At the time the mechanic had sorted out the misfiring and th eonly symptoms i had left where the slight matchbox ratle sound that u couldnt really hear. I had no idea that this was the sound of knock. Fast foward 2 years and on my seccond newly aquired r33.
I am rather paranoid about knock. I have a SAFC neo but i am reluctant to bother tuning it as it has no knock readout.
Do you guys think i shoudl get some sort of knock readout or bte the bullet for a PFC.
Is there a cheaper way than a PFC?
Cheers
https://www.sau.com.au/forums/topic/152072-knock-with-stock-ecu/
stock ecu will not let you know of knocking, it will just carry on in the background and drop to the low octane map when it picks up enough knocking.
So even tho it drops the map it still cannot protect u from blowing ur motoer for sure.
And it has no driver warning if this happens.
Is this a similar map to R&R there for experience the same power loss?
once it picks up enough knocking to activate the low octane map mode it drops to the lower octane map. basically it see's knocking and assumes youve put in penis fuel (95ron or lower) so it drops to the low map.
the low map is really retarded timing, so it would negate any knocking you were seeing. the timing would be really really retardard, the car will work, it will just be boggy and sluggish i would expect
i am unsure if r&r is a map change (i dont think it is) once the ramp is triggered it activates r&r which is probably a quick negative adjust to timing to the whole map and richen up by a precentage on the inj map
both i think are temproary (say 4 seconds of it) and then it backs off, well it could be 4 seconds or it may until the afm signal drops again
That all soudns very logical,
I dont understand then how i dusted a piston in my first r33 running 9psi of boost. I know it was pining but it it had stock ecu and 98ron fuel the ecu wold drop map and it should have saved it self???? shouldnt it?
I am concerned wiht my current r33 as the dyno turner has given it 25degree advance timming, he says the car just doesnt wan tot do any hting on normal base timing for some reason.
ITs getting tuned again this weekend as i am concere dit may not be safe, some times it get sluggish and other times run ok, i reduced boost from 10 psi to about 8-9 psi but it still experiences the inconsistent performance.
pinging is a lot worse then knocking, so that's propably why the car died. I have an SAFCII and it's whows up knock, i see as high as 30 sometimes when the car has been sitting in the sun olday and then i go to drive it, but after 5 minuts after i swich it off, it returns back to 10 or so. My car goes much better with the knock at 10 then it does at 0.
Pining/knocking? i know them to be the same thing i may be wrong.
I have a safc neo i purchased but hte damn thing doesnt have a knock read out. Does any one know of a wire mode for the neo so i can read nock or any other aftermarlet knock gauges?
Thanks.
ok here you go.
Pinging or Pre_Ignition
Pre-ignition is a different phenomenon from detonation, explained above, and occurs when the air/fuel mixture in the cylinder (or even just entering the cylinder) ignites before the spark plug fires. Pre-ignition is caused by an ignition source other than the spark. Heat or hot spots can buildup in engine intake or cylinder components due to improper design, for example, spark plugs with heat range too hot for the conditions, or due to carbon deposits in the combustion chamber. Spark plugs with a high heat range will run hot enough to burn off deposits that lead to plug fouling in a worn engine, but the electrode of the plug itself can occasionally heat soak, and begin glowing hot enough to become an uncontrolled ignition source on its own. Bits of carbon that build up in a combustion chamber can also heat soak to the point where they also are glowing hot and ignite the air-fuel mixture before the proper time.
Pre-ignition and "dieseling" or "run on" are the same phenomenon, except in the latter case the engine continues to run after the ignition is shut off with a hot spot as an ignition source. Pre-ignition might cause rough running due to the advanced and erratic effective igniton timing and may cause noise if it leads to detonation. It may also cause "rumble" which is fast and premature but not detonating combustion.
This heat buildup can only be prevented by eliminating the overheating (through redesign or cleaning) or the compression effects (by reducing the load on the engine or temperature of intake air). As such, if pre-ignition is allowed to continue for any length of time, power output and fuel economy is reduced and engine damage may result.
Pre-ignition may lead to detonation and detonation may lead to pre-ignition or either may exist separately.
Knocking or DETONATION
The fuel/air mixture is normally ignited slightly before the point of maximum compression to allow a small time for the flame-front of the burning fuel to expand throughout the mixture so that maximum pressure occurs at the optimum point. The flame-front moves at roughly 33.5 m/second (110 feet/second) during normal combustion. It is only when the remaining unburned mixture is heated and pressurized by the advancing flame front for a certain length of time that the detonation occurs. It is caused by an instantaneous ignition of the remaining fuel/air mixture in the form of an explosion. The cylinder pressure rises dramatically beyond its design limits and if allowed to persist detonation will damage or destroy engine parts.
    • Hi guys . Can someone help me  I bought an Android screen for my Nissan fuga but it won't turn on
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
