Dude it takes patience to sell a car
its cheap enuff already!! plus the used car market is shit house at the moment
Good Luck!
yeh i know dude... but when its cheap ppl should snap it out.... its real cheap..... PPL take it into account... must be sold....... and the main word here is must be sold... otherwise someone will get the bargin at the auctions....
water restrictions dude.... IF PPL WANT TO BUY COME AROUND MY PLACE CHECK IT OUT WITH UR OWN EYES. IT IS CLEAN CAR ALL AROUND...... WHEN BUYING A CAR PICTURES ARE NOTHING... 0402090079 must be sold.....
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
