No offence to anyone that has a TT, but they seem like RICE to me... Your car won't cool down sitting still while running, you need to drive it around slowly so the air flow can cool it. Ever noticed on a hot day that your car gets warmer sitting at the lights, then cools down once you start moving again?
That is the whole explanation (in a nut shell) to why they are not worth having. And that they are a great place for a car thief to hot wire the car from...
Cheers
Luke
I always thought that a turbo timer wasn't just to cool the turbo down, but to give it a chance to slow down before shutting off.
Your turbo wheels can get up to a fair few rev's per minute while under boost and I for one like the idea of letting the revs slow down before I cut all oil and coolant pressure to the engine..
Just my 2cents
  • Replies 60
its to let the oil and water cool down in the turbo by flowing through it after a thrash rather than switching it off with boiling oil and water in it and it cooking. my turbo spins for a good 40 secs or so after i switch it off, even when idling.
  • 1 month later...
this thread is old but i think i found a boost controller and turbo timer in one
http://cgi.ebay.com.au/Electronic-Boost-Co...1QQcmdZViewItem
im not the smartest when it comes to reading specs ect.... so any one that wants to review this item for me and let me know if its worth its weight in $$$$ please feel free
Edited by loymclure
Cheers
Luke
i laugh
your not cooling your car, your cooling your turbo with the oil and water flow
Edited by yokotas13
Repeat of similar posts for many years............
Turbo Timer…..YUK
What do you want one of those for?
They are just an easy place for someone to steal your car.
Ooooo, I have to cool the turbo down after I thrash it.
Yeh, but what about the gearbox, didn’t you thrash it at the same time?
Oooooo, better buy a gearbox timer
What about the diff, didn’t you thrash it at the same time?
Oooooo, better buy a diff timer
If you were really driving fast enough to heat up the turbo then you probably used the brakes it to stop in the driveway.
Oooooo, better buy a brake timer
Surely it makes more sense to do a lap of the block to cool the whole lot down. Not just the turbo, idling in the driveway.
:O cheers :woot:
Wel when your gearbox glows bright red....you might want one, but intil then dont bring that point up nad get a tranny cooler...
Same deal.
come on man, these arguments are lame and dont compare at all
Same deal.
The turbo is designed to run red hot, the gearbox isn't.
The engine oil cooler doesn't work unless you are moving, no airflow.
Ditto manual transmission cooler.
Similarly diff cooler.
Brake rotors get hot spots and warp unless they are turning while cooling down
Basically sitting there with the engine idling does nothing for everything else and very very little for the turbo.
Do a lap of the block to cool it down, it's better for your car.
:O cheers :woot:
lol holy shit balls
i just wanted to know if there was one or not, i dont do any laps to cool down right now due to my lazyness. and i think a turbo timer has its ups and downs but who cares its better me having one then not having one, and if there really are coolers out there for all those things you mentioned lol then ill buy em to. i think this thread is about what is out there not if its a good idea or bad idea im pretty sure there are heaps of threads like that already. whats the bet you have all done your own mods to your cars and they are all FKN sic mods and whats the bet that people have said "no it cant be done" or "thats a shit idea" i know SK has a fKN out standing reputation for knowing his shit and being the first to complete rather extensive mods. cheers for your input. but i want heaps of goodies for my car and if it gets stolen let the insurance company deal with that and if parts break let my bank deal with that.
NOW CAN SOMEONE FKN TELL ME IF THAT FKN EBC/TT IS WORTH THE PRICE THEY WANT?
cheers guys
now i know my reasoning may sound really rice... but i fail to see why all the big brand names like apexi and hks with such a reputation to uphold will venture down the turbo timer manufacturing path just to capitalise off others ignorance with no real benefits to using the product.
I have a TT in my car (a generic brand one tho) ....normally i set it to 0 mins...but on some spirited driving days i'll leave it to run for 2 minutes before shutting down
lol holy shit balls
cheers guys
EBC ...yes definately worth the price...although some are using the $22 manual boost controller without any problems..so its all a matter of whether u rather spend the extra money elsewhere...
TT ...u can get a generic one which works just fine.
I haven't seen anything else around that does both these things in one unit. No idea if that unit in question is any good or not...
You can get a bleed valve for ~$20 or an Apexi AVC for ~$500
Turbo Timers start at around ~$50 or so second hand
Up to you what you want and how to spend, if you can find someone to tell you that the unit in question is a good buy then go for it. Looks kind of big, hard to tell, is that thing a whole DIN size?
Cheers
Luke
:no: cheers :down:
i read somewhere that the turbo actually continues spooling after the engine is turned off and therefore with the engine off and the oil pump obviously not running....the turbo spools without any oil and may cause premature wear on the bearings, the turbo timer is to keep the oil pump running and feeding the turbo whilst giving time for the turbo to slowly stop ....but hey...i probably read that off the back of a turbo timer packaging (aka marketing gimmick)
The turbo still spins while idling under the turbo timer's control, EXACTLY the same as it does when you let the engine idle under your control. The turbo doesn't know it's the turbo timer holding the idle.
Turbo timers were of some use when we all had plain bearing turbos, with heavy rotating mass and mineral oil in the engine. Now we have balls, lightweight turbines and compressors and synthetic oil in our engines. Time has passed the turbo timer by.
Spend the $50 to $500 you save on not buying a turbo timer on making the car go faster or handle nicer. It's much better value for your money.
By far the best value for money boost controller I have used is the Jaycar IEBC, have a read of the thread on it as to why.
http://www.skylinesaustralia.com/forums/in...showtopic=61207
:no: cheers :down:
Next post off topic will be deleted and warnings handed out.
Stay ON TOPIC please.
Clint obviously wants to buy one, so only answer his question on wether the one he is looking at is worth it or other suggestions ONLY please.
OK, that turbo timer is a waste of money.
:laugh: cheers :P
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
    • Hi everyone, I've been wrestling with this for a while now and have been trying to find out the cause. For context, the turbos used are Garrett 2860 -5s, the BOV is a BNR32 HKS SSQV IV kit, the car is currently tuned to ~470 whp on 17.5 psi. The car drives normally, pulls well when it doesn't happen, and I can replicate it fairly easily. It does not sound like turbo shuffle or flutter. The engine has only a thousand or so miles and has had this behavior since it was completed. After my engine was built for my R32 GTR, I noticed that the car now sometimes makes an air discharge sound on what appears to be positive boost pressure that sounds really similar to a BOV. I had thought that it was a BOV issue but even when replacing it with a brand new unit, the sound persisted. It seems like it's coming from the passenger side but I may be mistaken. The closest scenario I could find was this post here https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/https://www.gtr.co.uk/threads/maybe-a-boost-leak-opinions.147955/ started by @yakshii and it sounds very similar. As in, at partial throttle once I reach positive boost I begin to hear the same psh psh psh psh psh sound like air is leaking somewhere when I keep the throttle in the same position. It most commonly happens in 4th gear at around 3-3.5k RPM and 5th gear around 2.5-3k RPM, which seems to coincide with normal positive boost thresholds. It might be similar to what @Austrian GTR mentioned about his own HKS SSQV. Notable difference would be that when he applies more throttle when it happens, it stops. In my scenario if I apply more throttle during this repeated psh psh psh sound, the cadence of the sound gets faster and louder rather than stopping. If I lift off slightly and apply throttle again, it will normally stop and pull without issue. I've checked all rubber couplers to ensure that they are tight, but have not gotten the opportunity to properly do a pressurized boost leak test. If anyone has had similar experiences or thoughts on what might be the cause, I'd be very keen to hear them. I also have a video of it happening from inside the cabin, if that would make it easier to understand: https://youtu.be/2zqZXcx8jbA
