1990 BNR32 Skyline GT-R
Imported and complianced April 2005 (15 y.o rule)
136,XXX genuine k’s (still has original speedo)
Engine:
R34 N1 Turbo’s (.64 housings)
Tomei stage 1 cams
Tomei Adj.cam wheels
Sard 800cc injectors
PWR Cooler
3” Custom s/s system, with custom dumps
N1 Water pump
K&N Filters
Oil catch can
OS Giken twin plate clutch
Rebuilt gearbox (12 months ago)
Re-conditioned radiator
Apexi Power FC (non DJ)
Blitz Dual SBC Spec-R
Wheels & Suspension:
17” Enkei Racelines (Custom painted Black on green pearl)
Maxxis Tyres with 90% tread
HR Adjustable Coilovers
HICAS Lock Bar
Other:
Carbon Fibre bonnet (also comes with original bonnet)
HKS boost gauge
Sony CD / MP3 player
Pioneer speakers
[GUN_R32] plates, included
Price: $25’000
Phone: 0414 532 561 or (08) 9185 5432
The car is in remarkable condition and certainly does not have the usual ciggie burns, holes in dash, faded paint etc. of similar examples. As I work away, I havent even done 10’000k’s since importing it nearly 2 years ago, it spends most of its life in my garage. Also, as the car was stock when it landed, every modification listed has been carried out here in Perth by Imports101 and Hyperdrive, all with receipts (Totalling 20K)
The current tune is courtesy of Lumpy at Hyperdrive, netting 370rwhp at 1.2bar. It has run401rwhp @ 1.4bar on another dyno, however for safety & everyday street driving, 370 is more than adequate. Prior to having the injectors and cams installed, I ran a 12.3 at the Plex on ****ty 19” Tempe’s, so the potential for a high 11 is certainly there.
Finally, the car had been for sale briefly last year, however constant timewasters made it hard for me, particularly being away up North. I am open to reasonable offers, but please, genuine interest only. More pics avail upon request. Interstate freight can be arranged if required. PM or phone me on the numbers above. Cheers, Rossco.
https://www.sau.com.au/forums/topic/152572-32-gtr-25000/
Bump for a georgous looking GTR.
Im looking to purchase a GTR in the next couple of months hopefully, this would of been perfect. Will certainly call if it's still for sale then.
https://www.sau.com.au/forums/topic/152572-32-gtr-25000/#findComment-2848041
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
