  • Replies 45
NAr not skins, whole new cars, Whiplash has been using an Aston Martin DBR9, & a Ferrari F40 :laugh:
my bad, wrong link
http://forum.rscnet.org/forumdisplay.php?f=1116
gives you an idea where to grab them from.
as it's an official site illeagal copies seem to be off lmits but they still tell ou what to kind of search for.
Cheers
https://www.sau.com.au/forums/topic/152580-gtr-2/page/2/#findComment-2880472
at the moment there is a C6R, Pigani Zonda, Ultima GTR, Mc Laren Longtail for the public. the dbr9 is being made by the same guys that did these and hasn't been released yet link
http://www.austraracing.com/shared/misc/WS...tmasEdition.rar
I'm part of a commercial game development team that does a few free mods for the community hence the f40 which will be released soonish. :laugh:
pics of our F40
http://forum.rscnet.org/showpost.php?p=336...amp;postcount=8
https://www.sau.com.au/forums/topic/152580-gtr-2/page/2/#findComment-2881259
Nice one thanks! 'downloading now'
New times 'starting to get competitive now! :laugh:'
Bugatti: 1:33.810
Saleen S7
I reckon I can shave off another .6 with my current car set up, but might have to further tweak car setting for a better time. It’s a bloody hard track to get all corners perfect, certainly can’t do them all good in a single lap just yet. I just did like 15 laps & my 4th lap was the fastest :|
https://www.sau.com.au/forums/topic/152580-gtr-2/page/2/#findComment-2881373
lol now i might clear off the desk and get the steering wheel out. Will have to use a standard car as the f40 has more power (going into turn 1 at bugatti at 300+) is lighter just badly suffers under brakes and in the aero so i'll keep a level playing field :blink:
have to organize a SAU online race sometime :P
https://www.sau.com.au/forums/topic/152580-gtr-2/page/2/#findComment-2881426
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
