with my set up power goes from 274 rwkws at 17psi to 346rwkws at 25psi thats 10rwkw per psi but with a stock turbo it may only be 5 or 6 rwkw and that would give you an extra 15 to 18 rwkw but turning up the boost without additional mods to a stock set up would probably almost go back wards without a larger exhaust cooler and aftermarket ecu. then at 12psi with these mods 180 rwkws would definately be possible.
https://www.sau.com.au/forums/topic/152654-psi-kw-ratio/#findComment-2839662
efficientcy zone, 12psi just creates more heat, plus there is no direct rule for psi to kws, as theres so many other variables to include that can alter results, ie: exhaust, fmic, fuel, filterchoices, as well as outside or intake temperature (cooler means more, hotter means less) and many more that will determine what power you get, not only that dynos all read different. And before a mod says it there are plenty of results under the search function as well as check the dyno results in the FI area, then you can gather what you may or may not get or close to it, from the information that is listed.
Cheers Adam
https://www.sau.com.au/forums/topic/152654-psi-kw-ratio/#findComment-2839759
It has to do with the whole package.
The compressors ability to flow at the given pressure ratio and the turbine/hot sides ability to allow that air to flow out of the motor.
As you increase backpressure (smaller turbine housing and turbine wheel) you reduce volumetric effiency as less air is able to easily flow into the cylinders.
This is why bigger turbo's make more power on the same boost level, there's less back pressure so greater VE so more air flows in to the cylinder easier hence less boost required to make the same power. :P
https://www.sau.com.au/forums/topic/152654-psi-kw-ratio/#findComment-2839834
i noticed on mine with stock turbo, 7 - 8 psi made 190kw and 11 - 12psi made 209kw. anything more than 12psi made bananas
bananas wouldbe worth alot 6months ago.
anyway.. thats because thats out of range for the standard turbo. it needs a bigger compressor housing. its creating far too much heat too. :laugh:
https://www.sau.com.au/forums/topic/152654-psi-kw-ratio/#findComment-2840787
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
