Just Engine Management - Dyno Day & Group Buy - Coming Soon 2007
J.E.M Exlusive SAU Offer
54 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 59
Posted Images
SAFC tune should be fine but ill verify that asap... hopefully in the next couple of weeks ill be able to get an official SAU group buy for all your dyno, tuning and ecu needs! but as i said prices will depend on intrest so more people = cheaper dyno, tune or custom package...
Cheers
When i last spoke to Adam at J.E.M he assured me that if we can get a decent number of people for ECU & Tune or Dyno Tune he will give us excellent prices. The reason why i setup the poll is to give him an idea of how many cars we will get for a tune... this will determine the prices.
People are spending thousands on performance products and for only 10 - 15rw/kw gain... so it makes more sence to me to get a professional tune for a lot less money and for 15 - 30rw/kw gain as well as reliability...
On the 20th of Feb my car is booked in at JEM for a Haltech E11v2 supply, fit and complete tune for $2800... This may seem alot but compared to other places this is quite cheap...with more cars, prices will be much cheaper...
TUNE HOUSE Quoted me = $3000
UNI GROUP Quoted me = $3200
HITMAN Quoted me = $3200
I got these quotes as a comparisson for you guys, I personally wouldn't let anyone touch my car besides JEM...
I'll be getting the Group Buy organised in the next couple of weeks...
Regards,
Sarkis
The Dyno power run is putting your car on JEM's Dyno.. Get 3 runs with a maximum power print out including:
- AFR
- Torque
- Kms/h
- RW/HP or RW/KW Graph
Adam will also let you know on:
- The general health of your motor
- If the car is running lean/rich
- Tips on what to do next to get your car running better.
Nothing on the car is touched... cause timing alteration .etc. falls under tuning and it requires much more time. So unless you got an aftermarket ECU, its pointless mucking around with little tweeks which will cost you dyno time..
A dyno power pass is MUCH more then just seeing how much power your car is making. Its also an indication of:
- How safely your car is running
- If your car is out of tune, timing or A/F mixtures
- As well as an indication if your car is running at maximum capability.
All that for $50 is peanuts! So lets start getting a list together of who is in for sure and we'll organise a Dyno Day... Maximum of 6 cars per Dyno Day....
Dyno Day #1 List:
1. jeffworld2
2. r32woohoo
3. lastlineofdefence
4. KIRUSS
5.
6.
Regards,
Sarkis
Edited by QRI05E
Thanks for the Positive Feedback stuartr32.. Adam is an exceptional tuner as well as a very honest an straight forward person. So if you want best quality and most friendly service... JEM is highly recommended!
Regards,
Sarkis
i would be in, possibly bringing some of the ctown thread guys, but i am on holidays from the 5-11th next month so cant make it then. if we get 5, can we come as a seperate group whenever we have time?
thanks for giving us this opportunity to do shit cheaply :pwned:
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
