For most 'normal' people, a three inch does all that it is supposed to (less restriction). Anything bigger is for show or really, really high horse power applications (you do actually need some backpressure to run smoothly/properly for anything remotely like daily driving).
Forced induction cars don't need backpressure anywhere near as much as NA cars. Because the turbo forces more than 1 atmosphere of pressure into the cylinder, it's pretty well "sucked" out by the lower pressure atmosphere behind it.
It's also the main reason why extractors are more suited to NA cars. Not really because NA cars have more to gain from the extractors, but because turbo cars have less to lose from an inefficient exhaust manifold design.
I think 4" dump would be too big for a normal street-driven GTS-t and sap a little performance, but I think the same pipe would absolutely kill the performance of any normal NA car.
You cant have too little back pressure. Think about this, people spend alot of time and money getting the air in and OUT of the head as easily and quickly as possible - head porting, heat wrapping, etc - all designed to get the air out quicker. Back pressure will not help this, it will fight it, it will retain heat in the cylinders. What possible good does it do in the pursuit of hp????
The cat is a BIG restriction to the flow of the exhaust. If you ever get the chance have a look inside one - its scary.
I read a post by Sydneykid where he flow tested a 3" (or was it 2.5" - Sydneykid) pipe, and found no restriction to air flow up to around 600hp air flow (help again Sydneykid!) or more.
Another thing to consider is what mufflers/resonators are fitted to the exhaust. I originally fitted an N1 style exhaust - very loud but made boost very quickly and gave a good power increase.
I then changed to a Nismo exhaust with 1 muffler and 1 resonator and I noticed the car slowed down, and made boost later. Both systems were 3". Sorry I can't back this up with dyno figures.
My personal advice would be to get the biggest diameter, least restrictive exhaust that you can - it cant hurt! Then fit the highest flow cat you can find;) you'll love it.
The design of the exhaust is as tricky as you make it.
The most forgotten dimension by exhaust upgraders is the 'thermal' one (and it relates directly to exhaust gas speed). At the start of the turbo exit the gases have incredible heat (and therefore speed and pressure) ,as the gasses travel back the speed of the gas reduces as its energy is lost to the pipe and radiated as heat.
Here is where it gets hard. The cooler gases are best not put through overly large pipes as it can increase turbulence but, smaller pipes have a larger surface area to volume ratio to lose heat through!
In practice I have found that the largest diameter should be at the start of the turbine outlet, any larger and you create unnecessary turbulence. Factory turbo --- 3inch from memory. Think 'match porting' at this stage.
Next the cat needs to be as close to the turbo as is practical, better still lets forget you have one (they kill power).
The first 3inch muffler needs to be nice and close to the dump pipe and filled with stainless packing (fibreglass will usually die and turn the muffler into a marracca) Exhaust places directing you to fibreglass mufflers will never place a muffler very close to the dump for this reason.
The second muffler before the diff @ 2 1/2 inch and 2 1/4 over the diff into a slight megaphone shaped tail pipe that tappers gradually out to 4inches.
Wrap the dump pipe to the first muffler or cat (which has been ceramic coated) in heat tape. If you have the money coat or wrap the entire exhaust.
If you tell people to reduce exhaust pipe diameter as you go back on a street car exhaust , they look at you funny and think your a loon.No it's not about backpressure, it's about retaining a low pressure 'trail' all the way back to the tail pipe. Hi I'm certified ! :P
I forgot to mention that the design is one that goes from 'hot' to 'cold' front to back and as that relates to high pressure to low pressure your home and hosed.
Then again if you can trap all the heat in then a uniform diameter of 3 inches all the way is the shot.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
    • Ah coolant overflow, previous discussions make way more sense now lol.
