for some reason i think thats the hks hard piping kit
yeah that's what I thought at first, doesn't look flexible to me...but if you look closer at the seal showing the sides, I think those are just silicon seals with large width shiny clamps, making that solid appearance..
after HKS ones only at visible sections... prolly require 2-3 ..all the remaining seals under dun really matter just normal cheap cheap silicon...
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
