Hey guys, in a few weeks ill be fitting a set of Deatschwerks 555cc high flowed injectors into my S2 R33 GTST. Just wondering, would i need to get a set of new O-Rings?
Currently there are no leaks or residue near the injecor rail so it all seems to be sweet.
Regards,
Sarkis
https://www.sau.com.au/forums/topic/152793-do-i-need-new-injector-o-rings/
Yeah the cost of new o-rings is nothing so they would be crazy not to supply you with a new set as a safe guard.
When you reinstall them make sure you use some vaseline and twist them as you work them back into the rail so you dont nick an o-ring.
www.nengun.com
www.greenline.jp
www.justjap.com
www.otomoto.com.au
Theres a start anyway! :D
BTW: post a wanted ad in the wanted section of this forum aswell as places like firesport.com etc
Edited by Godzilla32
QRI05E,
are you sending your old injectors back for a cash back?
$25 USD each injector thats $190 AUD for a set of 6 you get back.
You pay $519 AUD for a set of 555cc sidefeeds minus the 190aud cash back and thats $329 aud for a set of injectors.. Pretty darn cheap.
Hey cubes, my injectors were shipped today :P and they cost $555 including international postage.
$1 per 1cc lol
Yea i might send my injectors back to them, ill have a few things to sell once all my mods are finished so ill post them up on the FS section and see how they go...
Ill keep you guys posted on how these injectors perform!
Regards,
sarkis
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
