Time to get some funds to keep modding. A few things are up for sale.
1. Apexi AVC-R
Installed in ute currently, worked flawlessly, comes with almost everything (except box) minor scratches to unit (a little buff wouldn't hurt)
$400 posted
2. Exhaust manifold and dump to suit 3RZ Hilux
Exhaust manifold, and about 2 meters of exhaust from dump pipe to gearbox crossmember
Exhaust manifold designed for Nissan turbo. Was running a VG30DET high flow, but will work with anything off a R32/R33 T3 turbo. Dump is HPC Coated
(if you want a turbo, i can organize one)
$700 posted
3. RZN149 Petrol Radiator
Kept my turbo 3RZ relatively cool. Would be a nice upgrade for anyone who needs slightly bigger. Removed since have gone bigger (for new bigger hotter turbo)
Recently rodded to be cleaned out. No damage, comes with stock hilux mounts.
$200 posted
4. Turbosmart Vee-Type BOV
Slight damage to adjustment device, but aesthetic damage. Works fine.
$100 posted
5. GFB Mach1 BOV
Comes with plumb back fitting, plumback spring, as well as the mach1 trumpet and spring. As well as GFB Sticker
$120 posted
6. Intercooler
approximate core size is 650x300x55 has 2.5" and 3" inlet/outlet comes with ADRAD bar and plate core. Can cut down inlet/outlet pipes to make shipping easier.
$150 posted
7. GFB Bleed Valve
typical bleed valve
$50 posted
8. Aircon kit for Hilux (3RZ Petrol)
Comes with compressor (may need to be rebuilt) new exchanger, new dryer, most lines (i think im missing one), and cabin exchanger (may come with box)
$600 posted
I am negotiable, but will ignore stupidly low bids. Pickup available.
I will post pictures up tonite, i have some on my server already.
Some items are still installed on car but easily removed.
I am willing to trade on some items, i am looking for:
EBC (other then the AVC-R)
600x300x100 intercooler or similar
3RZ-FE engine, must be rebuildable condition
Edited by -==L=a=N=c=E==-
https://www.sau.com.au/forums/topic/152811-lances-cleanout-sale/
hey, if you dont mind me asking, but what feature do you need that the avcr will not do?.. im tossing up on avcr or greddy profec 01.. and this is the cheapest avcr ive seen.. im also on the coast..
ohh, any pix of the Intercooler?, any piping?
Edited by seriesII
G'day,
AVC-R is good at what it does, but the hours upon hours of fiddling to get it running right is annoying me, especially everytime i change something minor. I used an eBoost before this, and i want the eBoost simplicity back again (3 settings).
I have set the price as to not get those annoying PM's about "will you do it for $xxx shipped" It is the cheapest one around 2nd hand. And therefore price is FIRM.
No piping for intercooler. Pix are above.
AVC-R Sold
GFB BOV - Sold
3rz Exhaust+Dump - Pending Sold
New item added.
600x300x100 Intercooler - bought it but doesn't fit.
Never been used.
$220 posted
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
