i was watching targa :D
you were better off. I Had a squiz on saturday. Considering it wasn't wet there was a few offs!
powercruise was shithouse I reckon, the last 2 were reasonable. I wont bother going back ever again.
Edited by Mr. Untouchable
bugger that. too much exspense for too little race time. I'm thinking along the lines of super series. targa b sorta thing. mm maybe in a year or 2.
then again there's a few stacked up targa cars at work that would go cheap lol
would be fun as i reckon, out of interest how much have to set aside to make your car compliant to targa regulations funz? Saw around 8 skylines all up in targa and on the woodbridge hill there was an SL/R5000 on the back of a tow truck with a sore nose.
biggest cost that ive encountered atm is rollcage and seats.. and thats not including the cost of entry fee, new semi's to run with and general maintenance to run the car and also the fact i need to buy/get built a hi flow turbo :) all this stuff here is looking at 8k+ BUT i plan on running the car in hillclimbs and track days all the time so im not just spending the dosh for targa :D
www.targawrestpoint.com.au has all the regs on what you can do :-)
Good luck getting the 350 passed for Targa with the engine mods!!!
he doesnt have any engine mods :S lol
Just spotted some BS^^^^^^^^^ :P
Also saw the red R35 this morning in Salamanca
what BS you talking about lol... me rather confused lol
BS is IN BOLD ya computer tweaking geek!!!
YUP! pretty sure i remember seeing this car about at powercruise!
Should of come and said hi :D
Some dude named chris got some footage of me so i asked for the rest and here it is!
Fking RED Holden Drives taking off like grandma :)
Its ok there was like 10m room but you cant see in the vid !!
http://www.youtube.com/watch?v=pQ9-PgPNvBM
and that footage shows exactly why I couldn't be bothered with Power Cruise.
Get out there on a proper track day with only 4 or so cars and full use of the track...
Much more fun if you ask me :blink:
And yes I am friends with the guy whos car the footage is taken from and also the guy in the "Fking RED Holden" as well.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
