hi there just a heads up if yoru interested, i got the top half of my plenum polished but have since purchased an after market plenum so ye if your interested mine will be up for sale. im not sure if youve gotta price but its a c**t of a job to get the casting off and polish up.
if your interested its yours for 200 exhange with yoru stocko one.
can see pics ere
http://www.skylinesaustralia.com/forums/in...st&id=60546
Edited by humz
mick briffa is awesome his work is quality hes done all the fab work on my car and hes good a polishing hes done a few bits on my car
would go see him
hes in a new workshop now in same complex
dont hesitate go see him :miner:
yah seen him, seem like a nice guy.. he said will get it done 1.5weeks
actually that workhop looks more thatn just doing polishing job, is he mechanics as well?
cheers, been great help
i'd recomend ceramic coating rocer covers (actualy anything you plan to paint get ceramic coated)
its high temp resistant and wont flake away over time like painting does
comes in metalic colours or a chrome finnish, the chrome finnish is a bit more expensive..
its also good for coating exhaust housings on turbos, as it keeps the heat in which technicly helps spool the turbo faster.
competition coatings in kelmscot i think it is, look it up
this is my mate Anthonys rb25
ceramic coated rocker covers, brake booster, wiper motor,power steering pump, alternator and pullys
vinci chrome in malaga polished the plenum (top and lower), turbo comp cover, cas and ignition module and looked after chroming various parts and brackets
going to this extent in detailing isnt cheap haha
That is so god damn sexy. That is exactly how I plan to do mine so now I have to change my ideas. Looks like all shiny for me then. I will give briffa a call tomorrow to get the rocker covers, plenum and all intakes done.
