  • Replies 73
just thought i throw me two bob in :no: ive had to pull one of my ceffy dashes apart many a time and did notice that all globes have very easily removable green silicone sleeves so its a very easy process to make the dash white blue green etc hooray hooray
ceffys are like the greatest n that ever :yes::D
wwooootttt!!!!
https://www.sau.com.au/forums/topic/153344-i-want-i-want/#findComment-2854730
we need a confirmation though of someone with a spare cluster
as that has digi clock yet white dials...
i dont wanna pull my cluster apart this weekend to find out it cant be done easily or f**k something up trying to do it
and yes 11/10 FTW! p.s. i need my front rimsys here - another week to go :)
https://www.sau.com.au/forums/topic/153344-i-want-i-want/#findComment-2855173
Tools needed:
- Medium sized Phillips head screwdriver
- Small size Flat head screwdriver, or similar flat tool for bending tabs.
Time taken, 30mins tops, most likely 15mins.
I am completely trashed after a full day of drinking, so it took me 15 mins just to remove cluster.
There are 4 screws in the cluster surround (the bit with air vents).
There are 4 screws holding the cluster in, and 4 plugs connected to the back of the cluster (probably 3 or 2 if you have factory manual).
Once the cluster is out, and in your hands, clear a space on your work bench (or equivalent area).
Looking at the cluster, you will see the clear cover has 4 tabs at the top and 4 at the bottom, push these tabs in to remove the clear cover.
Don't fiddle with the gauge needles, you will probably put them out of calibration!
Then there is another plastic surround, also 4 tabs at the top and 4 tabs at the bottom, remove this too.
You will now see the individual gauges and if you look hard enough, you can see the green sleeves around some of the bulbs (1 either side of the speedo and tacho, making total of 4).
The sleeves are difficult to get to, so you need to remove the gauges completely.
Looking at the back of the cluster you will see 3 bolts behind the tacho, remove these.
Lift the tacho carefully from the cluster.
Now you have full access to 2 of the green sleeves. Use your flat head screwdriver to get the sleeves out of the cluster.
Reinsert your tacho into the cluster and replace the bolts into the back of the tacho, there are 4 holes for bolts. Put 1 in each side and 1 in the top.
Repeat the same process for your speedo.
If there are any marks on your gauge face plates or clear cover, wipe them clean, then replace the plastic covers.
Replace any bulbs if you removed them.
Plug the cluster back into the car and screw it in place.
Test it works properly.
If all is good replace the cluster surrond and screw it in place.
You may see that the gauge faceplates have a green coating on the back, but this doesn't seem to affect the colouration (much).
Once completed the gauges look alot whiter, but if you are picky like me, you will notice they aren't as white as the picture in the first post, they look a fair bit orange. This is probably due to the fact the standard bulbs are incandescent.
In this other post, a guy has replaced his R33 dash bulbs with compatible aftermarket parker bulbs, I will investigate tomorrow whether this is compatible with cefiro and if it makes decent results.
http://www.skylinesaustralia.com/forums/in...;hl=LED+cluster
Edited by daisu
https://www.sau.com.au/forums/topic/153344-i-want-i-want/#findComment-2856476
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
