attempted the white dial mod to dash cluster last nite
took 2 smokes straight and i had it done with all the green caps removed and reinstalled (did it in carpark whilst eating hj's as i always carry 3 toolboxes with me full of tools (just incase!))
only problem... they were a yellow tinge... so today took cluster out again and installed phillips ultravission hyperwhite/blue globes...
the cluster is now super bright - i love it... however it now has a green tinge due to the factory dials green coating... so im wondering how to fix this? it has been mentioned to use thinners on the dials to remove the green?
any recommendations?
look closer at the pic i supplied up top there is no green on the cluster... he has removed the factory green on the dials... will thinners work and not f**k shit up? what to use?
  • Replies 73
In the same boat, the cluster looked orange, so I used three T-10 Narva Arctic Blue bulbs and the green coating is now visible. I couldn't find anything T-5 sized though, except for these Monza LED bulbs, but I chose blue and it actually coloured that part of the dash blue. :)
I'm hoping this green coating comes off with a wipe of thinners :(
i hope so too as im super keen to get uber white
also noticed that 1 of the smaller bulbs (not parker size) lights up the speedo from 120-180... so everything on my dash is bright and tinged green apart from that part which is duller and yellow
This is the T-5 bulb that I was talking about, I'm gonna go looking in other auto shops today for something suitable.
led bulbs look shit... just want normal white
went to autobarn - narva do have t5 sized wedge bulbs... i picked one up $2 each... its just normal white not arctic however they said they do do a super white led t5 size - which i will try after i try this normal narva t5 bulb... i really dont wanna use led's as it will mean having to replace all the phillips ultravision ones i just bought and wont be as bright...
just need this green coating gone - whats the go???????
tried to remove the t5 bulb from its holder... it wont come out! not without breaking it... and had a better luke at the new t5 bulb i got which is just basically a new factory normal one so i dont think itll do much
sent the mrs off on a mission tomorrow to find an ultrawhite t5 to match the t10 phillips ones ive put in
she also came up with the idea of tinting the clear plastic cluster cover in 20% tint... so shes doing that tomorrow (hope it doesnt turn out shit!)
ok i finally got home from working on my car, i tried the thinner thing and it works.... but i wouldnt suggest it because it works on the plastic too lol, if your very careful it will look good , i didnt have another part to the cluster to try prepwash on but i think that will do the job perfect. pics in the morning... its sleep time now :D
when f**king around withe my cluster again last nite
i noticed on the back of each dial up to about 80 it is green... then 90 to about 130 or something the lines are white on the back... then green again to 180... wtf?
take pics of the back of the actual dials removed from the cluster? how did it go getting the white and green off? also that shit doesnt feel like it would come off... it sounds like a zipper when you run your fingernail over it
SCORE!
gf did browsing on the auctions this morning. 90-91 cefs had completely different clusters with factory white... i just purchased one now which will be here in 2 weeks... tacho goes up to 9k instead of 8k aswell
no more dicking around with factory cluster
now we wait... if anyonelse wants a late model cluster i can get several more... pm me :action-smiley-069:
ill put pics up tonite of one
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
