As my clutch doesn't exist right now, i'm in search of a replacement.
And i need some opinions. I don't drag race, and am more of a highway/twisty road road driver than a hard launcher (altho i tend to punch it for overtakes) - that being said i have quite wide rubber under the bum (265/35/R18). Currently making 194rwkw, but looking to do the GCG Hi-flow route in winder so aiming for ~270rwkw.
I'm curious as i can pick up an exedy from the business section in the forums reasonably cheap ($360 apparently) but is it worth it to go and get a Jim Berry Clutch? I don't really want to have to change my clutch again for the next 40,000 km if i can get away with it.
The Exedy kit says it will handle 300 rwkw, but does anyone have any reasonable experience with both the models? also the G/F drives the car as well, so if the Exedy (or berry for that matter) is overly heavy, it will pretty much rule it out.
Advice, comments and experiences would be much appreciated - thanks guys
Edited by nsanity
https://www.sau.com.au/forums/topic/153497-exedy-vs-jim-berry/
i just chucked one of those exedy 8 puk cushioned units in an it seems to handle 280hp fairly well atm. and the woman drives the car to and she seems so drive it no worries with her tiny little legs.
i got a jim berry clutch in my skyline and ill will always go back to him, he is the authority in cluctches but in sayin that hes not cheap, my 5 puck button clutch cost me close to a grand but havent had one problem with it since i put in in about 7 months ago, not even a hint of slip and i clutch it heaps. And surpisingly its not that heavy on the foot considering its got a 3600pound pressure plate. I love it. But if price is ur main concern ive heard the exedy clutches go well aswell and like u said u can find them cheap everywhere. hope this helps, lucas
Edited by drf76
Jim berry all the way. I put one in my mates 300rwkw 33 over 18 months ago, copped abuse all the time and his girlfriend drove it to work everyday. Recently did a heap of mods and its now making 400rwkw, clutch hasnt even looked like slipping. Jim berry also guarantees his clutches not slip. He told us he wants to go for a ride in the car if it does!!
in the end, i've gone for the exedy HD organic clutch.
Mostly because i simply couldn't afford the time off the road for my car. This does mean that come winter when i upgrade the turbo and whatnot, i will probably need to pickup a jim berry special. Which i'm fine with.
I'm driving it in atm, with roughly 500 odd km to go before a readjustment is done.
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
    • There's restrictor pills in the stock boost control hoses. That's how they set the amount that was bled off and hence the "high" boost setting. The usual mod in the day was to remove it and send the "high" boost setting up to about 14 psi.
    • Thanks Duncan, that's the best info I've read. Furthermore after learning about the PCM programming side controlling the factory boost solenoid, the purpose of the solenoid is to "bleed" boost when pin 25 is earthed, thus allowing spring pressure in the wastegate actuator to overcome diaphragm boost pressure, thus closing or reducing the position of the wastegate flap creating more boost as the turbo is able to spin faster. It's pretty cool to see a designated Pill to do exactly this, would have liked to have seen it with a tiny filter over the end for those moments in vacuum.  The constant bleed pill has now been removed completely from the system and solenoid boost control has been restored once again.   Case closed 😂
    • The wideband reading is meaningless if it's not running. Why are you using shitty old sidefeeds on any engine, let alone a Neo? What manifold and fuel rail are you using to achieve that? Beyond that, can't help you with AEM stuff as I've never been their ECU/CAS combo.
