Not sure what others would charge but its not rocket science.
Requires access to a datalogit and a little loom fiddling which is bugger all. I'd say in all, 30mins to 1hr max in labour providing the bloke doing the work has half a brain. :)
  • Replies 162
but Dan tells me that they can all be stuffed in behind the original ECU
I havent done this yet because im waiting to get it tuned then ill install it properly
:) you make me sound brutal, seriously though my Field harness was literally folded in half with the excess wires sliding into the cavity behind the ECU.
so how much beer would it cost me to get the 26 pfc installed in my stoopid 25t then ?>
cuase otherwise im going to save up an get me a emanage ultimate...laaawt of saving though
a faq for the emanage would be very useful
its not a matter of beer
but a matter of changes, adaptions and known "gotchas" when using the rb26 PFC on rb26
the biggest known gotcha is no VCT support at all
if you have aftermarket exhaust cam gears then this point is void.
in summary;
you need to copy the stock rb25 maps onto it (need datalogit)
need to parrell up the afm signal (single afm into twin afm ecu)
need to parrell up the 02 signal (single 02 into twin 02 ecu)
rescale injectors down to rb25 size (unless u have larger ones)
but there are plus sides;
djetro option
working air temp support
can use twin or single afms if u want (both work)
can use twin or single 02 sensor (both work)
and u can buy it new from most apexi distro's (nengun comes to mind) for $890 delivered
ive been thinking about buying a 26 pfc for a while now
and just trying it on my car as i have datalogit
but the main worry is the wiring loom changes
i guess i could open it up and make the changes
ap engineering style
how many would be interested in a custom "ap engineered" style PFC to suit their rb25
it would mean however no working VCT support. if you have aftermarket exhaust cam gear then this problem is void.
it would involve me buying a 26 PFC and then making some changes to suit your rb25
Might be worth checking out if jaycar has anything suitable to trigger the vct from an rpm signal.
I know I've said that before paul but surely some one on this site should be able to easily sort somethign?!? :S
http://www1.jaycar.com.au/productView.asp?ID=KC5378
:pirate:
So hows the vct work?
Just above idle it enables, then at the preset 4700rpm for example it disengages again.
This increases overlap during the mid range to aid turbo spool and mid range torque, over 4700rpm it turns off as to reduce overlap and prevent reversion etc due to backpressure which by doing so helps top end.
yep
i had mine turn off at like 1900 for a bit of fun
and the car was sluggish and drove like a bucket of poo
thats not to say it would do the same withit complelely off
I think you would need 2, one set at say 1,200 rpm to turn it on and one set at say 4,700 rpm to turn it off. You could install them at the ECU and use the same pins in the ECU plug as the standared VVT. Pretty simple actually.
:) cheers :huh:
Clint32 built up his 'hardcore' r32 gtst track car.
Was awesome to look at.
He purposely retained the vct and 9:1 comp ratio and still made the power he wanted. GT3040 on the engine dyno it pulled 580hp at 26psi.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
