RB20DET - Silvertop
About 120,000kms - had intermittent knock - would be really quiet then would come on really loud - but would come and go. Motor always ran stock turbo, about 14psi.
$325 - I guess this would best suit rebuild - suspect bearing noise!
Item is sold without turbo & lines, coilpacks, CAS or throttle body
RB20DET Gearbox
Was whining a little in 3rd and whining badly in 5th gear, synchros all seemed fine however.
$250
R33 Grey Door Shells - $200 each
RB20 R32 Coil Packs - Almost BRAND NEW - from Nissan - 5000KM - don't fit my cefiro :stupid: $220
R32 GTST Clutch Pedal - $150
R32 GTST complete pedal box - $250 (all 3 pedals)
A31 Cefiro Front Coils, and Super Low - Super Stiff Springs - $100
Items are in North Brisbane
Prices are negotiable
Contact via PM
Edited by rso84
https://www.sau.com.au/forums/topic/154031-rb20det-gearbox-r33-parts/
