they're not the quiestest of fuel pumps but they do a decent job and the sound isnt that bad its just a buzzing sound.
ive got a walbro 500hp one in mine and its a hell of alot quieter then my friends 044 plus mine has that little white sock thingo on it to help out.
kye
https://www.sau.com.au/forums/topic/154051-fuel-pumps/#findComment-2865359
I've got a Nismo pump in the GT-R, and it whirrs fair loud when you turn on the ignition, but yeah thats the only time I can hear mine.
G'day James, how much is a nismo one? Where did you get that from, whats it rated too??
https://www.sau.com.au/forums/topic/154051-fuel-pumps/#findComment-2865591
I got it from www.nengun.com
Just checked the prices, one for your 34 is $331.30 delivered atm (good exchange rate)
High Flow Nismo Upgrade fuel Pump. 4.6 L/min( at P=294kPa,3.0kg/cm2), an increase of 125% compared to the standard pump.
I chose it because it's a straight swap for the stock pump, I think with the Bosch and Walbro's you have to modify the cradle it sits in?
https://www.sau.com.au/forums/topic/154051-fuel-pumps/#findComment-2865602
modify the cradle yes, but it takes 15 min, and it flows a hell of a lot more..
what sort of dollars are you going to spend on the chase of kw's
https://www.sau.com.au/forums/topic/154051-fuel-pumps/#findComment-2865616
I'll always be spending (its a skyline)! Looking at 250 kw at next upgrade, later down the track would like max of 300 kw.
then stick with the 044, get a aftermarket sock/filter from sprints of a 5ltr efi falcon, and rubber mount the 044 onto the stock cradle.
once installed you will never have to worry about fuel again until you go past 400 kws at the rears..
and it will sound the same as your stock pump.
https://www.sau.com.au/forums/topic/154051-fuel-pumps/#findComment-2865667
I had an 040 in my S15 and it was noisy as a mofo - so much so I had it removed and put in a Walbro instead .... the 044 is even louder - a constant buzz - especially when the weather is warm, hence the fuel pump works harder for some reason.
I am fitting a Walbro 255lph and Malpassi fuel regulator in the next month or so - I have had them sitting in my garage for months ....
https://www.sau.com.au/forums/topic/154051-fuel-pumps/#findComment-2866192
Got a 040 sitting right at the bottom of the fuel tank in the Stagea. Mod'd cradle etc to make it fit right down low, also got a direct wire feed from the battery. Very loud, like a commy I guess, but hey who gives a f#, with a Stagea and the seraphic glass windows and some *beats* you cant hear a horn let alone a pump, lol
https://www.sau.com.au/forums/topic/154051-fuel-pumps/#findComment-2867128
thanx heaps guys, can you hear it while your idling Matt?
Has anyone upgraded their fuel pump on their 34??
Nope but my exhaust is pretty loud
Steve at AMMAR did mine he built the brackets and mounts, did a quality job, you can listen to it next cruise
https://www.sau.com.au/forums/topic/154051-fuel-pumps/#findComment-2868142
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
