Ah cool, thanks Nick...
Joel, how much i want to spend and how much i got to spend are two different things... :) But i got about 8k to spend... Hopefully my block i bought from Nick will be arriving sometime this week and i just paid for a RB26 head...
500-600HP is fine for standard rods.. (shotpeened & polished)
why bother? unless of corse its for track/drag use...
If its a street driven car you will be lucky to be using a quarter of that power during normal driving conditions.
There are better things you can spend that 1200 on.
Cheers,
Trev
2200 turbo
400 WastGate
450 RB30
1500 pistons
1300 Rods
500 -600 Block prep
1000 Cams
800 injectors + rail
400 fuel pump
1300 cheap computer
2000 RB26head
BANG 11K +++!! :)
Bearings engine&cam??
head work/check?
Head Gaskets?
exhaust manifold?
Intercooler?
oil/air seperator?
Time on dyno?
Plugs & ignition?
Intake? (thottlebody?)
Piping?
Turbo lines?
Any cosmitic work? (polishing etc?)
Just to list a few things.
Just a little somthing to think about before we see your project in the for sale section. :D
If you can save a few $$ here and there (rods) you might get to the bottom of the list with some money to put fuel in it! :D
Trev,
I agree with your statement on rods but please note that even though the RB30 rods are strong they can bend and can you imagine the damage that a rod can do at say 6,000rpm with a piston as a fist to your head (RB26) and your prepped block from your callculations the damage bill will be close if not over $4,000 so im my opinion $1200 is a cheap insurance policy
My 2 cents anyway
Jordan
Sure jorden,
I guess what i am saying is that with a 8K limit, i would be better distributing my funds. not spending 1200 on the rods. You have to be realistic with yourself on what type of power you will be getting from 8K (its alot of money, dont get me wrong). But with that type of dollar range alloy/forged rods are not really needed and would usally be considered overkill for a project of that size.
Cheers,
trev
Well i already have turbo, wastegate, manifold, fuel pump (Bosch 044 with Volvo lifter to surge tank), i have injectors and computer, well does Autronic SM2 fit the bill?? I already got that installed... Plus GTR Ignitors, intercooler and that sorta thing... So i have 8k to spend on the block itself...
JNR24 i appreciate the shopping list, but i am much further along than your assuming... I'm not a newbie with a stockie who talks the talk, i'm taking the steps as we speak...
Thanks.
Alan.
Hey i just rang rocket industries......Eaglerods dont make a set of rods for RB25/26 or 30s.
the only people that do (according to "Scott" in sales) is Argo.
They make a "I" beam rod for $2200 (Retail) for all RB motors.
Does anyone know if scott is talking shit?, and there are some other aftermarket manufactures of RB conrods?
Cheers,
Trev
Thanks for your enquiry,the rods for RB30 are custom only cost is aprox
$1900.00 plus gst .Rods are special order only must be paid in full before
being made. Regards Mario.
----- Original Message -----
To: "mario"
Sent: Monday, August 11, 2003 3:09 PM
Subject: Fw: WWW Form Submission
> From:
> To:
> Sent: Monday, August 11, 2003 2:16 PM
> Subject: WWW Form Submission
> > Below is the result of your feedback form. It was submitted by
> > () on Monday, August 11, 2003 at 00:16:57
> > To: Sales
> > Subject: RB30
> > Email:
> > Comment.question: Hi i was woundering if you guys made a RB30 conrod?
> > If you do how much am i looking at for a set. (6)
> > I am running ARIAS -40 over forgies aswell.
> > Cheers,
> > Trev
Originally posted by Skyrine-Dave
which plenum would flow better.. RB25 or RB20 ?
My non-vct RB25DE plenum is exactly the same as the RB20DET plenum.
Not sure about the RB25DET from the R33 however I don't think it would be much worth worrying about.
Hi guys, some of you probably already know this, but just in case....
Carillo, Eagle and a number of other US manufactuers most definitely make engine parts for RB's. But they have supplier agreements with the Japanese tuning shops that prevent them from selling them to you. So don't bother sending an email or a fax that says "do you make XYZ for an RB26?" They will always have to say no.
The way to do it is to order the parts by dimension, something like ......
"Do you have a XYZ that is 150 X 50 X 8 X 59 grams?" Don't mention RB or Nissan. You will get a much better response.
Better still look the parts up by dimension in their catalogue, you might be pleasantly surprised.
Hope that is of some help
Here's a quick run down on pricing..
RB25DE Head - $750
RB25DE Head Reco & Mild Port/Polish inc VRS Kit - $1100
RB30E Short Motor - $150
RB30E Rebuild inc. Forged Pistons, Shot Peened Rods, O-Ringed etc. - $3000-3500
Injectors - $900
Turbo - $2000 - $3000
ECU in & Tuned - $2000
Misc Bits - $500
Thats your $10,000-$12000 peoples.
+ Labour if you get some one else to do the engine remove and fit.
+ Your RB25DET gearbox if you have an R32
+ Suspension if it is currently stock.
= Before long you have spent more on mods than what the car is worth :(
I didn't realise how quickly it was adding up.
Who cares.. :( I don't. :burnout: :burnout: :burnout:
if i dont want to use VVT i can just bolt the head on as if it was the rb25de head cant i ?
the head has the oil squirter for the cam, but if the block doesnt have this i can bolt the rb25det head onto the block and just not use VVT ? is there a need to weld or screw up the oil feed? of is it right to leave as is?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
