Bingo got it in one.
Still a bit sad no one has asked what i bought.
Also if anyone wants someone to ride with (i know no-one down in victor) let me know as i'll always be keen for a hills run.
Maybe someone could buy tangles bike and go with me?
mmmmmmmmmmmmmmm gsxr 7fidy
nice n light, nimble and pulls like a pro.
great choice of bike for the adelaide hills - keep ya weight over the front bars and she'll be true to you, Im sure.
might rego mine and grab it from the shop - see how the knee feels.
we all need some sort of stress relief and hills road riding was mine.
How are you with fiddling with the suspn? Id definately urge you to take time and get those setting right (ride, pull over, adjust, repeat 50 times, lol), as for power once shes run in a Yoshimura full system (see ebay), BMC air filter and PowerCommander would have it sorted beautifully.
HHHMM, might see you out there :(
:woot: man Id love a ride. its in the blood
Haven't taken delivery, have to wait a few weeks buts all good.
Firstly i'll set static sag and then look at futher adjustments.
I believe they even have low and high speed compression damping, so there is huge adjustment availble.
So excited.
I bought a GSXR1000 last year, hell of a bike, havent had any time to ride it though! Currently advertised for sale at the moment, how much did you pay for a 750 if you dont mind me asking?
16,000 on road.
I assume you'd want less for your 1000.
I bought locally as i like to support local business. And my dad and I have bought 4 bikes in total there now so they take good care of us.
16,000 on road.
If you can get out of buying the 750 id take $16,000 for my 1000. I paid $19500 for it in june last year. Ive only done 760kms on it, and its already got a yoshi tri oval muffler and rear fender eliminator, plus a cover aswell, its registered til june 15th aswell. PM me if your interested at all or know of anyone else that may be.
Edited by GRIM_R32
Thanks for the offer, but i love the flickabilitly of the 750 plus it has more than enough power for my skill level.
I will let people know that you have an excelent bike for sale though if anyone asks me.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
    • And I just realised that that advice is slightly nonsensical for a GTR, because you need 2 of them. But it is otherwise true.
    • Having had a reasonable look at the car, I'll be able to remove the (one time) rams and retract the hinge (they are held in the down location by a tiny (m3?) sacrificial screw) which will get it physically back in shape. From there if you remove the rams you need a resistor to turn off the airbag light (as Mark said, there are plug in kits and I might go that way because its reversible). And...per all the threads on here, even if you have the resistors to turn off the airbag light, the bonnet light will stay on as it writes to the airbag computer history - that is either replace the airbag controller, reprogam the EPROM (if I can work out how), or remove the globe from the dash. Having seen how sensitive this system is, if I had my time over I'd pre-emptively remove the rams, even on a road car, because this is all a very unnecessary pain in the arse. Reminds me, time to go and have a look at the Fuga too....
