Actually a SHIT LOAD!
The new C&C
Crysis (DX10 only - correct me if im wrong)
Supreme Commander
Test Drive Unlimited
Will get a bigger list later but thats all i can remember off the top of my head.
BTW get GTR2 in the mean time lol
C&C3 - Oh god I can't wait!!!
Supreme Commander is also looking pretty tasty, but I've always had a love affair for the Command & Conquer universe, Plus Tricia Helfer (Number Six from BSG) plays a Nod General so it's already going to rock :laugh:
ive been playing bf2 for a while and have just brought 2142 battlefield seems good fun
2142 is terrible :S played the dome and it was gheyer than some of the threads in the wasteland. i cant play bf2 anymore either as i got some f*kin ban off punkbuster :S
i saw the E3 vid for Supreme Commander. looks like fun :D
anything good out now?
If you like racing sims then we will be releasing some commercial games latter this year. We have the official licence for the
Champcar Series
Grand am series.
but they will be a while off at the moment
Some very good classic games have just been re released today.
Like Sam and max hit the road, full throttle, the dig, curse of monkey island.
They are much better than most games i have played in the past 5 years so i'd look at those. They are classic lucasarts games.
i work for a us/uk based company over the net which mean long nights before going to my day job :laugh: but its all worth it
and big games :( we hope ours will be big. Part of the development team i work for released a r factor mod 2 weeks ago and its already in the hall of fame :laugh: we were shocked but was defiantly worth the long hours put into it
Edited by Whiplash
Im assuming by your name you own the S14?
If so then i seen you leaving the same carpark every night lol
If not then my bad!
Either way thats awesome to hear i was thinking about doing a 3D animation course a few years bac, forget the name of the company but they are the ones that made Rollcage etc.
MONKEY ISLAND FTW IM SO THERE
    • I got a full sheet set of OEM copied stickers to replace all the faded engine bay ones, great quality too.  Came from England. Someone like that should be able to to make u up what u want so long as u have a quality image to show them 🤷🏻‍♂️
