Hey guys, i've been offered some R34 GTR injectors (part #0010 9718D) apparently 460cc in exchange for my spare RB20 box. What i'm wondering is 1) will they fit (do i need different rubber 'o' rings) and 2) will i need a ballast resistor from the 34 or 32 to fix the resistance difference.
Any info guys would be great, cheers.
https://www.sau.com.au/forums/topic/155140-r34-gtr-injectors-into-rb20/
Yes they will work as long as you set the resistor pack up to suit and the injectors are top feed?.
Do a search - this has been done to death.
At 40psi my R34 GTR injectors flowed 480cc.
They fit up perfectly but you do need to trim/melt a lug off the injector to fit up to the std plugs.
If your std inj plug boots are cracked look at replacing them with VL items, they are a direct fit to the gtr injectors.
I bought cheapo plugs from Motortraders/Coventrys. $16 a pair so total $48.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
