  • Replies 119
yess.. quite sometime... and i wish i could use it when people come up to me asking for songs, whilst i'm playing, with the same vague attitude.
I like to respond with a middle finger and a friendly "Get F**ked!" :)
Well im not that harsh, but its very very annoying and distracting when you have some random drunk person going "Can you play that track that goes dun dun duuuuun dunananandun dun??" when you're in the middle of a mix!! :laugh:
my point exactly.
