as topic state i have a hybrid fmic and about to install bleed valve. there is no hose going into the intercooler piping. did a search and ppl say they drilled a nipple into there intercooler piping. dont really want to do this. there must be a way to hook it up. any one done this b4? got any pics?
Theres a vac line coming from the throttle body down and under your intake pipe where your bov sits going to your carbon canistor, put a 3 way thingo (cant remember wtf they're called) and then go to your bleed valve there... or use the search button..
actually you need to make one up, do not put vacume to the wastgate, as the diaphram is not designed to work under vacume, it will get damaged. Best thing to do is to drill and tap the stock cast intake pipe, BEFORE the TB and put a screw in nipple into it. That is how i did mine, works well.
A nipple on the pipe would still have vacum?? woudlnt it?
Um... this doesn't make sense about the vacuume to the wastegate damaging the diaphram... doesn't the wastegate open and close on vacuume/boost pressure, isn't it designed like that from factory? And if you are right why does everyone that i've seen just run it from the vac hose, to the boost controller to the wastegate?
the hose that is supposed to go onto the intercooler piping is t-pieced into a hose that runs to where the intercooler pipe joins to the intake plenum if that makes sence. can i just join the bleed valve to that line. if that doesnt make sence ill get a pic later.
no as soon as boost pressure is released the spring forces the gate shut, there is no vacume on the setup, as the stock boost tap is placed before the TB. Introducing vacume to the diaphram can couse the diaphram to pull away from the shaft mounting plate thing, sorry can't remember the techincal name. If you do use a one way valve, ensure that it is placed before the tee peece bleed valve, otherwise you will get boost goign to the gate, and then it will stay open as it will still be under pressure.
the yellow line is the one that is supposed to be connected to the intercooler piping. if i put the bleed valve between the yellow line and the actuator i still dont see how it wont work because the standard boost control is hooked in there and why would the mechanic hook it up like that if its wrong.
As long as that hose has vacume pressure its the right one. Or am i wrong?
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
    • I hear that would involve some nice country road drives into the hills for Mark...
    • I thought I'd come back and add something I JUST learned. A Toyota LandCruiser with a 1HZ, mates perfectly with a bottle of Nulon brake fluid. As in, it perfectly screws in. Great make shift funnel when you cut the bottom of it off. This may work for your Corolla.   Unfortunately, tipping a 10L drum is much harder than a 4 to 6L bottle, and they no longer include the easy pour tap which was just perfection to use previously.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
