Do most people just mount the GTR pump to the GTST cradle (modify slightly) or do they get the cradle from the GTR and use that?
I have heard reports of noisy pumps so I want to make sure I mount it correctly..just wondering if I need to buy it with the cradle..
Thanks
Edited by benl1981
https://www.sau.com.au/forums/topic/155510-gtr-pump-into-r33-gtst/
I had an R32 GTR pump put in my R33, it whines and makes all those fuel pump noises (2 stage, high/low). I cant hear it with the radio on or window down, and when others hear it I tell them I have a fully sick Warlbro 044 Bosh race pump, specially modified for drifting. Gets me all the hot chickes.
Edited by Jordan
Jordon, probably incorrect mounting.
The thing is, sure, a gtr assembly may go straight in, but most people don't sell the gtr pump with the assembly. With the exception of those that have bought a complete nismo replacement which includes cradle (expensive), others who upgrade the pump replace just the pump and keep the cradle.
If it rattles, make sure you clamp it to the cradle harder.
Some people use a bit of rubber between the cradle and the pump, but I find that uncessary. Stock pumps and cradle don't use rubber, so it's not necessary. Just make sure it's clamped tight, so it can't move.
If it makes noise, add another hose clamp
Edited by MANWHORE
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
