Just wondering if someone knows 100% the do's and dont's of this joint?
I know b/c's, ecu's, aftermarket exhuast systems(noise) and pod filters or fmic will get you done.
What about coil overs and braided brake lines?
My brake lines i was told are ADR approved.
But what are these dudes gonna think of them?
Anyone had previous experience?
https://www.sau.com.au/forums/topic/155517-epa-macleod/
As stated above
EPA - Emissions
VicRoads/Vic Police/RWC - Mechanical/Road worthy/ADR items.
If i recall the EPA form has on it they are only checking the emissions etc.
You could always ring the number on the form and the person on the other end will give you a more detailed run down
https://www.sau.com.au/forums/topic/155517-epa-macleod/#findComment-2892005
man i hope i dont get an epa letter ill be f**ked.
im running realy rich atm and ive being told about it by mates.
ive got a chiped ecu, k&n pod, adv timeing exstractors and 2.25 exhaust. and my o2 sensor doen't work as i cut the sensor wire by merstake a while ago and haven't fixed it.
:D:yes:
https://www.sau.com.au/forums/topic/155517-epa-macleod/#findComment-2898153
F*cking sweet as then.
Dudes are freakin me out tellin me this and that!
Anyway just had my exhaust, pod and b/c taken out over the weekend.
It's painful going back!!!!!!!
Next is ecu then off to the EPA next wednesday. Wik.
https://www.sau.com.au/forums/topic/155517-epa-macleod/#findComment-2903722
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
    • Hey mate, really appreciate the help. Have been looking pretty extensively myself and was certain they were retro fitted, but then ended up finding a 4 door with what looks like the same side skirts or at least the closest I’ve seen. The photos from the Offset Kings event at Sunrise 2016. https://fatlace.com/offset-kings-okayama-at-sunrise/
    • Isn't there a PAR engineering gearset that has closer to stock ratios? And they claim they'll do whatever ratios you want.
