Fear not my Doughnut loving friends.
Cry not that we dont have our own Krispy Kreme clone like the other states...
For I have discovered the holy grail of goodness is within our reach....
Ok so i was having lunch in town @ the city cross and they got this great yiros place, and next to it was this doughnut place that sells glazed ones, choc ones, stuffed ones - like apple cinnamon, blueberry, raspberry, key lime pie etc...
They are exxy, but damn worth it IMHO. Around $2 each for a single one, or $18 for a dozen of the same, $20 for a mixed dozen...
ok enough talking
PICS :)
PS- Dont lick the screen, and this sh*ts like crack :)
https://www.sau.com.au/forums/topic/155607-doughnut-lovers/
been there done that.
got addicted...
had to wein myself off.
Hi, My name's Mick and I'm a gourmetglazeaholic,
group responds:
Hi Mick
hi micky hows the snapper fishing been did ya mrs finish painting ya boat yet ?
https://www.sau.com.au/forums/topic/155607-doughnut-lovers/#findComment-2895777
THANK YOU FOR YOUR INTEREST IN A KRISPY KREME DOUGHNUT CORPORATION FRANCHISE.
As you may be aware, we no longer have franchise opportunities/development rights available in Australia. We are not accepting applications at this time. Several markets are currently under development and stores will be opening soon.
Couldn't open one even if we had the money :mellow:
https://www.sau.com.au/forums/topic/155607-doughnut-lovers/#findComment-2897529
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
