Hey peoples,
Before u start asking for pics n stuff, these items are still installed on the car so I cannot provide photos as yet...however I will tell u that they were baught from autoban not too long ago and i still have receipt and warranty for the gear.
They are Currently installed on a 7m-GTE supra but can be fitted to most imports. They are:
* E-boost 2 with wires and instructions (actually in the instructions it has a diagram for the plug ins on rb20, rb25 etc)
* Greddy auto adjust Turbo Timer ($70)
* HKS SSQV ($200)
* 16x9 deep dish work rims with tyres (80% tyre) ($550)
* 2 Layer adjustable GT wing ($180)
the eboost2 I will not be generous on in terms of price as I paid $890 for the unit and a further $125 for install, therefore only offer me a reasonable price for it...lets say over $400 for those who are serious. I baught this unit a month after it came out in Aus.
As for the other gear, ill let you guys suggest how much u willin to pay for it
Edited by AARR34
https://www.sau.com.au/forums/topic/155628-eboost2gt-wingrims/
Guest hr324door
Hey peoples,
* HKS SSQV ($200)
Where are you located?
ya pics of rims and wing plz :)
will try to get some pics soon...all the items are in good condition if u need to know and need to go as I am stripping the ol bomb :P
oh and im located in brisbane
Edited by AARR34
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
