Hey peoples,
Before u start asking for pics n stuff, these items are still installed on the car so I cannot provide photos as yet...however I will tell u that they were baught from autoban not too long ago and i still have receipt and warranty for the gear.
They are Currently installed on a 7m-GTE supra but can be fitted to most imports. They are:
* E-boost 2 with wires and instructions (actually in the instructions it has a diagram for the plug ins on rb20, rb25 etc)
* Greddy auto adjust Turbo Timer ($70)
* HKS SSQV ($200)
* 16x9 deep dish work rims with tyres (80% tyre) ($550)
* 2 Layer adjustable GT wing ($180)
the eboost2 I will not be generous on in terms of price as I paid $890 for the unit and a further $125 for install, therefore only offer me a reasonable price for it...lets say over $400 for those who are serious. I baught this unit a month after it came out in Aus.
As for the other gear, ill let you guys suggest how much u willin to pay for it
Edited by AARR34
https://www.sau.com.au/forums/topic/155628-eboost2gt-wingrims/
Guest hr324door
Hey peoples,
* HKS SSQV ($200)
Where are you located?
ya pics of rims and wing plz :)
will try to get some pics soon...all the items are in good condition if u need to know and need to go as I am stripping the ol bomb :P
oh and im located in brisbane
Edited by AARR34
