Hey,
I've had a problem I have been trying to sort out, that is the car popping/misfire on load at 4000RPM and above. I have cleaned the AFM and put in PFR5G spark plugs in.
I have fixed the problem from misfire from 4000RPM - 6000RPM from there it will pop and hesitate between 6000RPM - 7000RPM before changing gear (automatic)
Any ideas?
Edited by ThugishPimp
https://www.sau.com.au/forums/topic/155639-quick-question-please/
well 5 heat range is too hot, most use 6
checked your coils for cracks? boost below 12psi?
Thats what I thought. Stupid Autobarn.
Would having the heat range at 5 cause this to happen? I've been told by many to use the heat range 7.
I'm running stock boost, coil packs are fairly new spitfires.
Thanks for your help Craved!
I have tried BKR6E also and had the same problem. After I cleaned the AFM I only had the misfire from 6000-7000RPM and not 4000-7000RPM.
I have been told to try heat range 7. I got a set of BKR7E. Should I give it a go? Only mods are; Modifications:
- K & N Pod Filter
- Cold Air Intake
- Forged Pistons
- Strengthen Conrods
- Blueprinted
- Balanced
- Port Polished
- Metal Head gasket
- Spitfire Coils
- High Performance Timing Belt
- High Performance Spark Plugs
- Gready Turbo Timer
I've put in all new BKR7E spark plugs. Took it for a run it popped/misfired between 6000 and 6500RPM then changed gears, didn't seem as bad as it was when it was popping/misfiring between 6000 and 7000RPM.
Went to a friends after taking it out, on the way back I wanted to see if it would still do it, and I had no problems.
Now, here's the problem;
This has happened before, it will miss/pop then run fine for 1-2weeks then it'll pop/misfire again.
I can only hope the heat range 7 plugs doesn't cause it to pop or miss in a couple of weeks.
Any comments, suggestions?
what fuel are you using out of curiosity ?
V Power Racing (100% with 5% ethonal)
is it in tune? That could also be an issue, trial and error. Changed fuel filter? Any knock? Injectors? O2 Sensor? hmmm run out of others.
Not sure
Adam
I've had the fuel filter checked, no knocks, injectors have just been cleaned. Not 100% sure on he 02 sensor, but when it was in the performance shop they said they checked everything.
They said it was most likely my coil packs but since the rebuild had just been done then I couldn't get it on the dyno and rev it too high.
5 is the standard heat range. if you're running close to standard power then colder plugs shouldn't be necessary.
Edit - popping and misfiring is very likely to be tired coil packs. Gap your plugs down to 0.8mm and give it another shot :huh:
Edited by Kinks
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
