Been searching the posts, can't find anyone who has changed the oil in an R34 auto box. Does anyone know -
1) How often should we do it (ie I'm not having any problems, but the car has a few K's, should I change it)?
2) I've heard that there is a oil filter in the box as well, is that so?
3) What oil is right for it?
4) Anybody done it and can share their experience - including the filter change (if there is one)?
Ian
k i do this for a living. to properly service ur transmission you have to take the sump completely of the car. from memory u dont have to remove the crossmember. yes there is a filter inside the box but its a pain in the ass to remove an its a mesh type filter which means u can just clean it out not replace it. on the sump there is a pan gasket which is recommended u replace cos itl just leak. or if u want to do it quikly theres the possibility ur sump has a plug in the bottom of it. just screw it out and wen u put it bak in put a new copper or aluminium washer on it or itl leak. its recommended u service ur transmision every 20000km or 12 months or if u drive it extremely hard change it sooner if u wana spend the money. oil recommended is a dexron 3 type oil and the filler tube is located drivers side behind the inlet manifold in a pain in the ass spot. hope this helps
Sif go to a transmission specialist. I've done this on other autos on my floor in the garage. It's not hard.
Just about 10-15 bolts holding the sump on. They're all low torque, so easy to undo. Drop the pan, dump the old oil, replace the filter, replace the gasket, replace the pan, fill with oil. Easy as.
I wouldn't bothe rwith the tranny specialist. Any mechanic can do it. I wouldn't pay more than $50 in labour to do it.
The tranny service kit comes with everything you need.
check the manual for the recommended amount of dexIII.
Keas can do it.
I've done it.
Yes it has a sump plug. Yes it has s cleanable mesh filter but it's not hard to remove but you do need to remove the pan/sump which means new gasket.
Also don't forget the torque converter is full of fluid so it's best to flush it which requires a machine that you and I don't have. Seriously, any auto transmission place can do it.
Next best you can do is undo the hose going to the trans cooler and drain from there - engine on in P til the flow stops. You then top up, take it for a drive and repeat. That's close enough to a flush if you ask me.
The tranny service kit usually includes the filter, sump plug gasket and sump pan gasket.
There's no need to get a tranny 'specialist' to use their machine to flush it. Waste of money.
What I do is undo the heater hose too. Then you'll get most of the fluid out.
Fill her up, start it, moev it through the gears, and check the level.
You can't get all the fluid out, btu that doesn't matter. Just do it more often.
e.g. when you do your engine oil, you can't get it all out. But that doesn't matter. The new oil dilutes the dirty stuff.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
