Hi people, sorry if there is a thread on this already, i searched for it but couldnt find anything regarding this directly. I just purchased a new nismo fuel pump and fuel pressure regulator (for my r33 gtst). no major engine mods apart from pod, fmic and ebc. bought the pump for the sake that im getting a custom boot done and affraid that it might be a struggle to get the pump in afterwards...
1) will i need to upgrade anything eg fuel lines???
2) is it ok to just replace the stock pump, leave the stock regulator (for now) and install nismo pump??? (ps: will eventually upgrade ECU to autronic one)
3) what about installing the regulator??? i know its adjustable, or can i just leave it off for now till i get injectors and ecu upgrade???
any suggestions appreciated ay...
thanks in advance, Jon
https://www.sau.com.au/forums/topic/155838-new-fuel-pump/
1) No you will not need to upgrade the lines.
2) Yes you can just change the pump and retain stock reg.
3) If you want to install the reg, you need to measure current fuel pressure and set the new reg to the same pressure. Otherwise it will overfuel. Once you have the bigger injectors and are going to reprogram it, you could raise or set the pressure as you choose.
https://www.sau.com.au/forums/topic/155838-new-fuel-pump/#findComment-2897411
sounds good, thanks for your help, so to read the current pressure i need a fuel pressure gauge right? i heard you can just place them under the bonnet correct? and can i then just record the pressure at idle rpm???
https://www.sau.com.au/forums/topic/155838-new-fuel-pump/#findComment-2897425
yeah, you can either fit a guage or get your mechanic to hook up an inline pressure guage/flow tester, just for the measurements.
you want to measure two pressures, pressure at idle with the vac hose connected and pressure at idle with the vac hose disconnected.
standard pressure will be something like, 32psi with the vac hose connected (20" vac) and should read 40psi with the vac hose disconnected from the reg (0 psi/atmosphere pressure)
just set your new reg to the measured pressures and you will be able to use it without remapping the ecu, if you plan to fit it before the ecu.
note: pressures are just an estimate used for the above example.
if you got a standard 1:1 ratio reg and set it to the same pressures it is of no real benefit of course, its only a benefit if you want to raise your fuel pressure quickly and easily to either rectify spray patterns on get a little more through your injectors, if they are to small.
at the end of the day, there is no real need for a fpr if you have correctly sized injectors, but it can sometimes be handy if you get stuck.
https://www.sau.com.au/forums/topic/155838-new-fuel-pump/#findComment-2897472
righto, cheers for that ay, didnt realise that really i dont need it but maybe it'll come in handy down the track who knows... :mellow:
https://www.sau.com.au/forums/topic/155838-new-fuel-pump/#findComment-2897505
I'm guessing you have a big ricer setup in the boot blocking the way?
In terms of possibility, sort of yes. How hard will it be? very.
The cap is pretty hard to remove. You really want to have as much space as possible to try and do it. Also, the inspection panel is really small, and there's all this crap in the way. You'd be bending aroudn the bend and having no force to open the lid.
Also, I don't like breathing in fuel, so i'd prefer to do it with the boot lid open to have more fresh air.
https://www.sau.com.au/forums/topic/155838-new-fuel-pump/#findComment-2901221
nah, i've just got the floor carpeted and my two subs sunk into the tyre well and have my two amps on a carpet board covering the battery etc.
can remove it though ill need to get it remounted by the audio shop... was just hoping that i could get through the other side. anyway if you advise that it is easier to go through the boot, then ill do that.
cheers
https://www.sau.com.au/forums/topic/155838-new-fuel-pump/#findComment-2901540
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
