2 problems, well questions...
Guest Boxhead
ok now your in here, basically, my car when its been turned on and just starting to go, the temp is down, which is ok, but the car seems to be missing a bit, the plugs...
now, is it because there old and need replacing? or is it because there gapped too big? or just coz there cold? now when the engine gets to normal temperature, they run fine...
ok second question, took brake pads out today coz they make a bit of noise, and i want to know what they are, a mate who helped me get them out, said that he thinks there not stock, but isnt 100%.. can anyone tell me, they dont have there name printed right on them so yeh.. dont ask haha.. the pic is attached
https://www.sau.com.au/forums/topic/15605-2-problems-well-questions/
What heat range you running? eg BCPR 5 ES ("5" is the heat range)
Don't think you wil ever tell who made the pads, or what grade they are. They look a bit "Bendix Ultimate", but you're not going to be able to get a definitive answer, I don't think.
cant see how a reset would stuff the aftermarket chip.. if its still based on the factory ecu it will still have all the self learing as factory and would benfit from a reset but theres no way it could stuff it, what happens if u had a flat battery.. start at the plugs and see...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
