hey guys,
im in desperate need of your help, one day i was on my way to work my steering was fine (no hicas light)
later that day i start my car and immediately my hicas light appears, but i noticed when the light is supposed to turn off there is a very quick flash so the light stays on,
its like iv got no power steering anymore and yes iv checked my fluids,
i got so pissed off i took to a workshop and got them to fit a hicas look bar with all lines removed.
but nothing has changed hicas light is still but i relaise is stay due to the lock bar but is as if i got no power steering.
can someone please help
https://www.sau.com.au/forums/topic/156371-uncommon-hicas-problem/
which fuse is it?
and i will see if its unpluged from the solinoid
i removed my hicas completely. including the solinoid in the engline bay. the power steering line that went to the solinoid got plumbed directly to the power steering cooler. this made it so i didnt need to replace the power steering pump. i still needed to physically remove the hicas light out of the dash as it stayed constantly on. the light indicates that there is an error with the hicas. there is no hicas anymore! thus no need for the light to tell you theres an error with it.
You can just cut the sender wire on the hicas computer. Bottom right of the smaller plug. Green with white trace line.
And that is the best way to loop the hicas lines. There are a couple of guides on here of how to do it, and I've done a detailed one on ns.com too.
Edited by salad
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
    • Hi @Chupapy i had several leaks from coolant pipes being corroded, i also had one leak on back of the head onto transmission. For me that leak was from the turbo water line. Follow the line to the back of the head The hose and metal pipe had perished these are the best pics I took of it at the time
