rb26 instalition
i've just finished the conversion ur thinking of , and OMFG there are virtually nil swap over and wait till u get to the mangement section. but there i a very bright light at the end of the tunnel, if u got time a tatience then do it as a the amount of little odds bits that have to be done, it would cost a fortune or they would quickly bodge it.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-320570
I personally wouldn't bother with the RB26DETT Conversion.
I would mod the RB25 up to 300rwkw if that still wasn't enough then by then you need to start toughening up the internals so i would look at slapping a 3ltr bottom end and rebuilding that instead of the rb25.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330304
i've just done the rb26 conversion but was running the autronic smc computer management system prior and found it quite easy.there was a slight mod to be done to the cross member,pulley to be pressed 5mm of the power steering pump to match 26 front pulley'and re-piping intercooling.radiator,throttle cabel,thrust bearing and gearbox all fit no problems.well worth the effort.i hope this helps.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330353
Originally posted by -Joel-
GTS500 how does the Power delivery feel compared to the RB25DET's? i.e off boost, spool speed, response etc?
Drive a GTR and that will probably give a fairly good indication maybe ?
Cheers
Ken
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330368
when the rb25 came out it had 320hp with a small turbo the rb26 has a large turbo that is laggy till 4000rpm and then turns the tyres hard until the rev limiter kicks at 9000.its wild but blew third gear in the box on second test drive at 500hp and 19psi on bp ultimate.its the best thing i've done
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-330382
2GU UP, depends on what you want the car for, if you drive it regulary just change the turbo and do teh usual stuff (cooler, exhaust etc) and you will make a easy 220rwkw. If you want more then you have to start decidng if it is worth changine the engine, but the costs will be much larger than doing a few simple mods.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-331029
I was fiddling around with a turbo calc last night and it appeard that what really hinders the RB30DET is the lack of rev's compared to a RB26. The RB26 will rev to 9000rpm where as the max the RB30DET can rev to is 7000rpm - 7500rpm due to harmonics.
Basically the RB26DET was better for all out power in the turbo calc.
However it isn't always about all out power.. No good boost coming in at 3/4 of the rev range for a street car.
https://www.sau.com.au/forums/topic/15656-rb26-instalition/#findComment-331056
    • Quick update, finally got an hour or two on a weekend where there wasn't shit weather, no sick kids, people visiting our house or had to work. Visited me old folks and the skyline...dropped  $10 of 98 in the tank and a brand new SCA shitter battery in. Cranked over a bunch of times but didn't fire up....pretty sure it's not getting any fuel. Gonna try some of the stuff suggested above, next time I make it over there.
    • @GTSBoyas luck would have it and it's legit the only part of this story that goes my way, I already had the liner out to retrim! So much lucky!
    • Drill out the subframe bushes, replace them, same with the diff bushes.
    • Sane enough. Remove the roof liner, because the acid will go everywhere.
    • Thanks guys, I really appreciate the help and experienced opinions.  I have spent a lot of my life working on boats so I'm pretty good with fibreglass. I'll take everybody's advice in here;  I'll cut a little more of the 2nd layer away as it's a bit crunchy rust and also it's sitting high now. Then I'll wire brush it all a bit to get off anything loose, then I'll soak the bejesus out of it all in rust converter. I'll make sure to get a little hose piece and feed it into all the holes and gaps between the roof layers. Then I'll fibreglass up the holes.  Then I'll get a pallet of filler and mix it with 3 buckets of hardener and hope that is enough to build up the roof corner.  Does that sound sane? Is one type of filler better than others for this?
