i am selling this for a friends.
it is a HKS EVC3 boost controler. He want it for $500.
If any of you interested pm and i will send the pic to you.
Control over how much boost pressure your turbo produces before opening the turbo's wastegate. Regulates boost by manipulating the wastegate vacuum control line. A computer chip CPU controlled boost controller. An accurate adjustable ****pit mounted electronic boost controller. Independently adjustable high and low boost settings that you can set from the comfort of your driver's seat. Also a scramble button for that extra kick when you want it at the push of a button. Includes an over boost warning alarm. Manually adjustable up to 200% of stock boost level. The solenoid is mounted on the engine side of the fire-wall and connected to your turbo waste-gate. The solenoid is connected by the harness to the control unit which is mounted close to your driving position.Used Boost Controller by HKS. Some minor marks and scratches as you would expect from a used item. Good working order when removed. Includes the controller, solenoid and wiring harness
https://www.sau.com.au/forums/topic/15725-hks-evc-3-for-sale/
  • 4 weeks later...
    • Hey everyone. Is there a way I can get the original window sticker (maroney label) for my 1995 R33 GTST? I doubt I’ll be able to ever get it but it’s worth a shot to ask
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
