hey again
wanna run my car down the 1/4 as i have previously stated but i want to be realistic and run with my street tyres.. i got 18 in rims on it now and wanna know what tyre to go for... either a 255/35/18 or 245/40/18?
a friend told me to go for the 245's cause of its higher profile.
i have no clue..
https://www.sau.com.au/forums/topic/157365-2553518-vs-2454018s-for-the-14/
You will probably get a faster time with smaller inch rims..
Im no expert either..
but i remember when i was at the drags, a guy from this forums put his stockies on and got a much better time than his 18 inch rims lol...
Anyways i dont think you will find some difference between them.. It will come down to your launch, and how well the rubbers grip..
Do the 255s, have better rubber than 245s??
im not too sure but a friend who works with tyres told me that the 40 profile is better for the strip
the larger profile will give you more grip as the side wall will have a bit more flex so in s triaght line you the tire wont spin up as easily, i would also lower your tire pressure to give you a geater contact area with the road
have fun at the drags
I'd say there would not be much in it running the 18s.
The 255 gives you up to 10mm more width. I say up to as a tyres width rating is a maximum width allowed meaning it could in fact be smaller. Wheels or Motor mag did a tyre comparo a while ago with a variety of 245 wide 17s and only one make of tyre (the cheapest) actually measured up to 245 wide, the rest were all narower.
The 245 tyre will give you around 9mm more sidewall which is ideal for drag but make your overall diameter 18mm taller.
I guess if one had to be chosen it would be the 245 but thats assuming both tyres are the same make etc.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
