orange...
weve been told above its in perth - and orange cef with same mirrors, same vskfs on the front and full uras kit instead of wonder... in orange... was at DA WA
Edited by Hella Flush
  • Replies 78
wanna explain the difference between aus spec vented front guards and jap ones
I was looking at a pair of "aussie" one Saturday and I cant tell the differance to the jap ones
apart from the little bit of mesh
Im confused so you bought this car and then painted it but your not happy with yourself
LOL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
mmk my bad on the guard thing dude... i thought it had dmax style with the double low vents (just looked at page 1)
same guards... hes just put chrome mesh in em
either way - if theyve resprayed it orange... big mistake
i tried to however stupid driftaustralia removed their pic thread "not for public view" is there excuse - some personal photographer had a photobucket with lots of pics of it... ahd vskfs on the front and some shit wheels on the back
trying to get the pics again!
might have to wait till i get home and check my history of it
PIMP DAT - thats the plan! :)
I FOUND THEM!
BEFORE
AFTER the australianisation - orange/black roof/bonnet+boot/uras kit
http://www.highoctanephotos.com/modules/ci...24_IMG_1002.jpg
http://www.highoctanephotos.com/modules/ci...24_IMG_1001.jpg
HERE GUMNUT!
dude still cant see the pic Im over it guys site is gay
even if I go in myself and find what I think should be the pic I cant see it
and stuffed if Im signing up just to see it
Edited by 1400r
I hate when this happens.. :wave:
And he had to choose the most stereotypical 'drift spec' color combo and kit going around... Nah f**k it I'm over it now. This has tipped me over the edge, what a f**king wanker seriously.. Seen too many tough cars go down the same route. The ex Japanese motorsport R33 is a prime example. f**king bogans
If he indeed owns 2 Cefiro's then my sincere apologies
As far as i am aware the orange and black ceffy is infact punks other ceffy. He has both the green one and the orange one.
There was 2 orange ceffys at DA. One in SD thats punks one the other in DA is Adam Trewellas RB30det one freshly painted in Ford Focus orange.
I could b wrong about Punk ownin 2 ceffys but i'm pretty sure he does.
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
