Hey all,
I'm looking at getting into automotive spray painting just as a hobby and am looking for advice on how to best get into it.
First thing is equipment...
I was thinking of just going second hand for the compressor. Is there a certain CFM or pressure I need? Is there a minimum size tank I need?
From what I've seen, entry level spray guns aren't that expensive. Will a cheapy do to begin with?
Is it worth doing a short coarse or just get some cheap paint and practice?
I'm not looking at doing an entire car, just some side skirts and possibly my front bar as a start. Can I spray the same color/type of paint as stock?
I've read before that OEM paints are 2 pack which you can't spray at home due to nasty chemicals in them. Could I get the same thing in acrylic?
Thanks
https://www.sau.com.au/forums/topic/157829-getting-into-spraying/
  • Replies 40
Posted Images
Im no spray painter by trade but iv done some cars in the past(acrylic). Iv learnt you need a gravity gun, good compressor that keeps a good flow of air and time, prep is the main key of a good paint job. hope that helps. Good luck
Hey budy done a bit aswell and one helpfull tip is that you should spend sixty to seventy percent of time in prep sand back, Undercoat sand back undercoat then top coat basicaly. Remember to not go for a full coat first (meaning) dont try to cover the whole area in one hit do an even coat same speed along each panel then you will avoid runners and "orange peeling" effect!!
Cheers for the advice
Can anyone give any insight into what colors/paint-types you can spray?
Since you not supposed to spray 2-pack paint does that mean you can't do any metallic colors or does it just affect how long the paint will last?
I think u cant spray 2pac unless ur on a approved premises, the stuff is toxic.
I thin ku can do acrylic at home as long as ur neighbours dont complain lol.
I am in the process of doing my bonnet at home in acrylic.
fist i used cans and did a suprisingly good back yard job lol
2nd time i used a super cheap spray gun with the cansiter below it turned out crap.
I just bought a gravity fed spray gun and im going to try and paint it gloss black with clear coat, in my clear coat i will put metal flakes.
So we will see how bad i can stuff this up lol
Im aboult to paint 2pac in my engine bay of my r31 drift car it takes a long time to dry but a lot stronger. Iv just paintd my bonnet and boot in black(acrylic) with a clear coat in it let it dry for a week after each coat 3 thick coats then a rub down after each coat. Now im up 2 cuting and polishing and that is the biggest c**t to do by hand lol so i went out and bought a buffer 100% better and quicker. Also if you choose to paint 2pac dont do it in your shed ;) unless you have a good vent system!!
;) for wanting to have a go!
First up, a 10cfm 2hp belt drive compressor would be ideal for parts etc, a 12cfm 2.5hp belt drive can do a car. The little mini compressors wont really cut it & will end up working too hard/ get too hot. Belt drives (looks like a fan belt set up, with 2 pulleys) are usually quieter than diaphram type (just the motor/pump on top, no belt or pulleys) too. Second hand or reco ones are fine.
Most cheapie spray guns are OK, 'Star' make pretty good entry level guns, you will want a 1.2-1.4mm tip. A "Conventional" gravity feed is the way to go, don't get a "HVLP".(one of my SATA guns is a high volume- low pressure gun, so even with it wound all the way in a fair bit of air still comes out... good for hosing it on but can be annoying for tricky areas) Just make sure you can turn the air pressure all the way down till no air comes out at all.
No, you shouldn't spray 2pac at home (but you shouldn't drink or smoke cigarettes either!) & you will get fined if you get busted.
Acrylic is great for beginners, and yes you can get all colours, metallics, pearls etc in it. Always wear a proper mask(Sundstrom or 3M are good), and be carefull about overspray when spraying... spray in the garage or in the backyard... move everyones cars out the front/on the street... dont spray when windy... etc etc
Look up your local smash repair supplies shop in the yellow pages, go say Hi & ask what gravity feed guns they have on special, should be able to do a package deal... gun, proper mask etc.
Again, your local smash shop supplier will sell all paints, & should be able to match to the colour of your car if you give them the paint code & petrol flap.
You can do short intro courses at TAFE, but costs money & time...if you're keen enough just have a go! Fill the gun up with water & "paint" your roller door/fence/wall/?? for a while :wave:
Good Luck!
try the trading post for smash shops closing down for good 2nd hand guns too
Edited by frogman
Hi i just bought a HLVP gravity gun wiht a 1.4 and 2.0 ml nozzle.
I was planning ot paint acrylic. So with the HVLP i will need to turn the pressure donw on the compressor? is that right?
I plan to paint a bonnet , plan is , primer, gloss black, holographic metal flake in the first coat of clear, then clear coat on its own to finish it off.
Cheers.
Cheers.
Sorry if I wasn't clear..when I said "just make sure you can turn the air all the way down" I meant on the gun, not on the compressor. Being able to wind down the air really low on the gun is handy when you want to paint small areas & for touch ups. My gun won't, but some do. If you feel that you have too much air, then yeah you can turn the pressure down on the compressor no problem.
With your bonnet, that plan is fine. Let the primer dry for a few days before you rub it down. Acrylic is pretty workable, so if you think your black looks a bit dodgey or the flakes are a bit too chunky, you can always cut it back between coats, re clear it then cut & buff it.
Great info frogman!
Exactly what I was after
Do you know of any sites that have a catalog of all the different types of paint/pearl/flakes etc ? I'd love to see the kind of effects you can achieve... I'm keen to get spraying now :D
Hey Frog man, thanks for the info! :(
With buffing does that have to be done with and electric orbital buffer?
Should i not even attmept to buff by hand?
And also what cut/polish should i be using?
thanks again.
Frost this might not help much but do a ebay search for 'metal flake'
thats how i found my holographic flakes to put in the clear coat.
Cheers
No problem guys.
Sorry frOst, don't know of any sites for colours. Probably better to go down to your smash shop supplier & asking them nicely if you can look at their colour chip books, that way you can find out how much they'll cost ya too.
tmc_2, You don't neccesserally have to buff with an electric buff, but it will take you forever to get it looking ok, especially a dark colour. Start by hand & see how well it comes up/how long it takes before you get sick of it I guess...
A proper buff (I got a top of the line 'Rupes' from cash converters for 80 bucks, the guy didn't know what he was selling!) is ideal, I've never used one of those two handle round things that you get from supercheap, but its probably better than nothing!
Back in the day when I was using acrylic you would use a lambswool buffing pad with a green compound called 'Farecla'(I think thats how you spell it) I know it is still used & available from smash supply shops, but I've only seen it in big buckets.
There is a small foam white & yellow buff pad which is designed for 2pac, but you could probably use it on acrylic, they are called 'G-mop'. I'm pretty sure there are a few cheaper versions of the same thing but I dont know their names. Maybe go for a softer one for acrylic, ask the guy at the shop what firmness would be better.
I use a compound called 'Pasta Abrisiva', by Gelson. Its in a small black tin with white yellow & red stripes.
Both of these compounds (which can be thinned out with a bit of water to make life easier), & pads will get all your wet sanding scratches out, from here you can go by hand or keep buffing...
There is a larger black foam pad called a 'waffle pad'. They are a bit tricky to use but when you work it out the paint comes up sweet.
I use a 3M compound, I'm pretty sure its called 'finess it', but I've lent it to a mate so its not out in the garage for me to check! There may be a new improved version of it now, but it still comes in a tall black squeezy bottle with red writing. Not sure how you would go trying to use this stuff by hand though, its ok for small areas where you cant get the waffle, but big flat areas, hmmm..
For polish, every one has their personal preferance. I started using 'AutoGlym Super Resin' about 10 years ago. I have tried others, waxes etc. but have always gone back to super resin. Its easy to use & has no silicone in it, silicone is a nightmare for spraypainters! The whole time I was in smash shops I just used clean white soft rags if i had to polish anything... the last time I bought some super resin they had a sale on proper terry towel polishing clothes, they are heaps better than rags :ninja: !!
P.S. All this stuff is just what I am used to. These products have been around for ages & are used by alot of smash shops. There are heaps of products & ways to do the same thing, if you use something else some other way & your car looks great, thats fine.
Ok painted my fibreglass bonnet on the weekend.
Put the primer down went ok, then sanded it and then i did a guide coat of black and sanded it. then another coat of black sanded it ao everything was smooth.
I then applied 3 layers of black. After that dried i did one layer of clear with holographic metal flakes. then applied about 3 more light coats of clear. I used 1L of clear and it was not enough. I think the because i have metal flakes i need to make my top coat of clear thicker.
Next week end i may attempt to cut it back a little and add more clear. I will post up a pic of my effot so far in the next day or two.
Im fairly satisfied for my first attempt. its not the best job tho.
The metal flakes cover up my mistakes :laugh:
Where did you get the flakes? How much and what type?
How do you cut back the clear? (cutting compound? that's not like sanding it back is it?)
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
