Im half way into fitting my trust frount bar iv got a 120mm thick fmic. Now the drama is i have to shave some plastic of my thermo fan so i can push my cooler back more. So im thinking of upgrading the thermo, saves me shaving it, just wondering if its worth it and what is good to use.The car is in the process of getting to make 250-300 kw
Cheers
Dave
https://www.sau.com.au/forums/topic/157841-thermo-fan/
I used a cheapo Ebay special ~$75ish a year or two ago. :)
The origional is 12" I squeezed a 14" in there that flows what feels like more than double.
If you do grab a thermo grab one with an S shaped fan blade. They flow considerably more and are much quieter.
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2931320
im using twin 10 inch daves carigs ( with the curved blades for flow and quietness) and they work really well in my lil crampt engine bay... jus ask any one who has looked under the hood
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2931666
there talking about air con thermo fan. not radiator thermo fan
i dont think Marvin has to worry aboout aircon thermo's
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2931710
I am just about to buy 2 of these
http://cgi.ebay.com.au/HIGH-PERFORMANCE-14...1QQcmdZViewItem
and chuck them in when I fit my new radiator. Also going to put in a Pivot fan speed controller too - temperature controlled thermo is where it's at!
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2932021
no worries cruzin33 we are all here to help :D
sweet Joel - glad to hear you are happy with it. I hoped I could get some feedback before I bought them :laugh:
With 2 x 14" (which will hang an inch over each side of the radiator) I will have 5,300cfm - which is a MASSIVE amount of air! And I will need it since I have a FMIC, putting on an oil cooler and upgraded trans cooler, plus standard a/c radiator, plus the new radiator.
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2932037
After your comment about the a/c pipes I went and checked my engine bay and you are right Joel - I will only just be able to get a 16" fan in there .... bugger .... oh well that will have to do. With the Pivot controller I will be able to control when and how hard it comes on, so will have to ramp it up on hot days accordingly. I am also going to rig it up so the thermo fan keeps running even after the engine is turned off, when the water is over a certain temperature. Since I am in and out of the car all day, and spend long times stationary idling with the a/c on, I need to do this to sort out my temp issues once and for all. On 40 degree days I have seen my water temp reach 115 degrees - yikes!!
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2932060
no idea and no idea. I am pretty handy mechanically so I am sure will be easy for me to install - but I can;t judge your competence :D
I am buying mine from a private someone who is looking to sell one.
I would try online retailers who sponsor SAU and nissansilvia.com if I was you.
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2939883
  • 3 weeks later...
I got the fan the other day took one week for it to turn up and it was worth it. It was packed nice and no probs with the dealer it also aloud me to push my fmic back 25mm. Now just have to find a temperature controlled thermo unit and find a new upgrade radiator, and im set :ermm:
https://www.sau.com.au/forums/topic/157841-thermo-fan/#findComment-2985782
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
