Hey guys ok heres the story! just last year i had my car converted to a RB25DET R33, when it was dyno'd after the installation ( car was fully standard ) besides the replica greddy type-s BOV, my car was boosting at 7psi? ...note: its not lsd, its still on N/A diff, but should get conversion when i get time and money :P
Right, now 2months later i installed a front mount 600x300x76, along with 38mm wastegate (16spring), HKS ssqv ( copy ver ), carbon fibre pod filter, and for interior just boost gauge n turbo timer.
now heres the question i wanna ask! my boost now reads 8psi? i was expecting somthing like the 10s after installing whats above? or am i wrong? is there something wrong? or do i need more mods to reach the 10 margin?
cheers
Edited by gl0ck.
https://www.sau.com.au/forums/topic/157942-boost-probem/
when i added my pod and exhaust i managed to pick up 9 psi . then i added my bleed valve ( manual boost controller - FYI ) and fmic , iv boosted mine to about 11 psi.
just pick up the one DMR posted . that seams to be the go , above all other mbc's... im looking to get 1 aswell
https://www.sau.com.au/forums/topic/157942-boost-probem/#findComment-2939046
    • New CAS just turned up from NZ Wiring. Looks like a nice bit of gear.  So, yeah. Triggered, bro. Realised I may as well do the cam belt while mucking about with it so will order one of them.
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
